Results 1 to 22 of 22
    Sep 2009
    54
    2.0 TDI BLB engine rattle
    I have a rattle which I think is coming from 1 of the pulleys on my V belt. How can I check which one it is??
    Jun 2010
    Glasgow
    take the v belt off and run it without it. This will rule out the driven items. Possible the alternator pulley is seized, you should feel it slip when quickly turning by hand. More than likely the noise is from the balance shaft. The BLB has a chain driven drive abd is common for failure
    Sep 2009
    54
    I believe my car is a later BLB with spur gear.
    Jun 2010
    Glasgow
    the BRE had the spur gear if your BLB has it then its be modified. Try removing the belt then, its a quick test and will rule out most things
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,147
    If you give your VIN to the dealer or someone with ETKA then they can tell you if it has the old-style, problematic chain drive.
    Fingers crossed you don't have the balancer shaft problem.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Sep 2009
    54
    I have been told that after a certain chassis number BLB engines were fitted with modified spur gear. How do I take off belt??
    Jun 2010
    Glasgow
    saying that theres still problems with the spur gear drive so dont rule it out just cause its not a chain
    Jun 2010
    Glasgow
    the tensioner has a 16mm bolt on it. A long reach spanner will access it and turn it clockwise to take the tension off. Take note of the route of the belt
    Sep 2009
    54
    Should all pulleys spin freelly??
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    You need to lock the alternator internals before trying to turn the pulley, it should turn both ways but may be a little stiff. I think you will find it will be that one seized.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Sep 2009
    54
    How do I lock alternator internals?? If I lock internals why would pulley still turn??
    Sep 2009
    54
    The fan blades in my alternator turn one way and not the other so i assume this pulley is ok. When engine is running the tensioner seems to move side to side on its spring. Is this likely to be my noise. If so are they easy to replace??
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    [QUOTE=P Crr;1008856]The fan blades in my alternator turn one way and not the other so i assume this pulley is ok. When engine is running the tensioner seems to move side to side on its spring. Is this likely to be my noise. If so are they easy to replace??[/QUOTE
    I think you are assuming wrong mate, it sounds exactlly like your alternator pulley is shot. The tensioner will move around like mad because it's trying to compensate for the lack of movement from the seized alternator pulley. A new pulley is 30ish from GSF, it's really common thing.
    RNS-E retrofitted
    Sep 2009
    54
    Just come back from local indie and they think either alternator pulley or air con clutch as switching on and off air con makes rattle more noticable. How can I check which one it is. They told me to let it develop and go back in a few month.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    The easiest test without taking anything off is to start the engine and turn the steering lock to lock, listen and feel for the steering pump juddering/squealing/ making noise. That will indicate the alternator pulley. Mine got noisier when the aircon was turned on and off. If you are handy with a spanner it's not a bad job, you just need the proper tool.
    RNS-E retrofitted
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    Thats lazy fot he garage, a few mins popping a belt or two off would have proved it there and then.
    Mine has a noisey aircon pump and clutch in that it maks one noise when aircon off, and a different sound when it's on on. When i drop the belt it's quieter than a silent thing in a quiet place
    Sep 2009
    54
    Will look to getting alternator pulley done as steering does squeal on full lock.
    Sep 2009
    54
    How do I replace pulley. Anyone got a step by step. Would prefer todo myself
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Quote Originally Posted by P Crr View Post
    I did it with the alternator in place, which on a golf required removal of the bumper, headlight and washer bottle (which was a pain in the hole!!).
    If you take the alternator off it won't be too bad. You need a special pulley tool, laser tools make them for about 15.
    Search it on google, you will find plenty of guides.
    RNS-E retrofitted
    Sep 2009
    54
    Thanks. Will have ago soon.
    Jul 2007
    33
    Mentioned this on aonther thred recently,I have what seem's to be the same problem,iregular rattley clattery sound which is getting gradualy worse with the air con selected 'off',it's almost elimnated with aicon selected 'ON'.tried turning steering lock to lock as mentinoed here on an eralier thred as a dignostic for the alternator pulley but no judder squelling no stranges noises in fact it elliminated the rattle for over a minute or so then it gradualy came back, just wondered if any one had proven it to be the alternater pulley, alternator is not siezed belt tention and all pulley's look fine with engine running,don't want to pay out for an A/C pump and find it's not,
    Jul 2007
    33
    FEED BACK ON THE ABOVE RATTLE WHICH HAD GOT PRETTY BAD, WITH RIB BELT OFF, ALTERNATOR PULLEY FINE, AIR CON PULLEY WITH ROTATIONAL FREE PLAY IN COMPARISON WITH NEW AIR CON PUMP NEW AIR CON COMPRESSOR FITTED ALL FINE NOW, GOT IT DONE BY A MOBILE GUY CALLED TO MY HOUSE DEGASED AND REGASED,CLAIMED IT WAS NEW DENSO COMPRESSOR (LABALED DENSO) TOTAL INC VAT 580 ,DONT NOW BY JUST REPLACING THE PULLEY SEEM'S A BIT COMPLICATED
