Chris NottJMB Retrofits
    Nza
    Nza's Avatar
    UDO Unidentified Driving Objec
    May 2009
    Earth
    32
    CLANKING Intermittent Sound Mashing Breaks
    Hi
    I have an Audi A4 S Line and I get a clanking intermittent sound coming from the right side. I also hear a slight metallic shuttering sound when I go thru rugged bumps etc.
    Last time I took it to the garage he opened to check my break pads and it was in tact. He also tightened up one coil and then the sound was gone. But as time went by the clanking sound re-occurred
    Anyone had this before?
    What do you think it possibly can be?
    North Wales
    9
    Hi check to see if the pads are moving within the caliper, I got the same problem, and it turned out to be the pads (moving up and down).
    Hope this will help
    Jun 2007
    131
    ...yep had the same issue..was fixed as above
    JohnyT
