Monster MotorsportVolks Autos
Results 1 to 9 of 9
    Oct 2005
    bristol, uk
    760
    Auto's: multitronic, tiptronic what's the difference?
    any major issues with these on the B7?
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    I was warned against the multitronic. Reports of it falling apart as low as 60k miles.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Good 2 B A Gooner's Avatar
    May 2009
    Chichester
    715
    Trip only - Multi have an issue with the ECU's seal in them split and the oil damages the ECU.
    Oct 2005
    bristol, uk
    760
    How do I tell which it has, as I'm sure some sellers won't have a clue lik
    e me now
    Oct 2005
    bristol, uk
    760
    i just read quattro would have tiptronic all others multitronic
    so if it was the case it would have to be tiptronic?
    but then i read somewhere b7 multitronic are fine it was the version before?
    Oct 2005
    bristol, uk
    760
    not sure if it's a good source, Honest John (well i like the comprehensive reviews)
    B6 seems like faults with multitronics, but not mentioned on B7. Someone said that 2005+ multitronic should be fine in comparison, thoughts and experiences?
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    I would stay away from the multitronic too.
    What engine's were you looking at?
    Oct 2005
    bristol, uk
    760
    well any engine really at the moment
    Mar 2008
    83
    The difference is as follows. The multitronic is a CVR Continuous variable ratio. Its a chain drive configuration that means you dont feel a gear change, it adjusts the ratio dynamically. It is a very smooth drive if you switch to manual mode it has software configured gears (either 6 or 7) so will simulate a gear change. I have owned two multitronics the first a 2.4 V6. If you floor it, the rev counter goes to the red line then the speed continues to increase with no dip or gear change and the revs stay constant. I now have a 2.0TFSI and it drops the revs each time It reaches the red line (I assume this is to take advantage of the turbo). I love the multitronic its beautiful to drive, my only complaint would be pull off. If you need t pull away quickly there is a 1-2 second delay in hitting the peddle and the car jumping off ( a pain at busy junctions) also then engaging reverse if you hit the throttle too quickly its like dropping the clutch on a manual it jumps with a thud, you soon learn not to do this. Sadly the multitronic is plagued with reliability problems and most people will advise to steer clear. The gearbox was originally a sealed unit and maintenance free for the life of the car, now they advise a gearbox oil change every 40K. This costs around 200 and is strongly advised. If you are buying a car with a warrantee then I wouldnt worry. If not check that the oil has been changed at every 40K interval as this will help with goodwill from Audi should it fail? My first one did fail and needed a new ECU, luckily under warrantee, my current one has been fine. I have a friend who has owned his from new and it failed after 5 years 80K at a cost of 5K L. The Tiptronic is a completely different beast, if you have a quatro it will be a tiptronic, these are much more reliable and supposedly very good gear boxes. So if you know the history and have a warrantee I would go for a multi tronic. Otherwise stick with a manual or tip. I hope this helps.
    08 Audi A4 2.0TFSI Cabriolet Special Edition, Electric seats, RNS-E Satnav, OEM BLuetooth, SmartTop
