EM TuningMonster Motorsport
Results 1 to 7 of 7
Thread: DTM Questions.
    Aug 2009
    29
    DTM Questions.
    Hi,
    I've recently purchased an A4 DTM and am wondering about ride height and suspension settings. Seems the arch clearance is greater at the front by quite some way (up to 20mm). At least that's how it appears, the car does however sit level overall but I think a more aggressive stance would be better.
    Does anybody know if this is correct and if not what spring / adjustment options there may be to drop 15-20mm.
    Also is Pipercross the only panel filter available and what experiences owners of DTM's have had of remaps.
    Many questions, so few answers.
    Thanks,
    H
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Dont the DTMs use the S-line springs which are 20mm standard?
    Im changing my springs on my s-line for some eibach 30mm, will give me a subtle 10mm drop and should sit right i think.
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    Mar 2009
    589
    Ye Dazmo DTM use s-line springs so 20mm lowered as std as he says eibach or H&R should give the car a small drop I wouldnt go to far as you could wreck the handling !
    DTM is same engine as any 2.0t so any 2.0t remap will do the job for you and give you about 240 -250 bhp.
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Don't bother with springs - save up & get some stainless steel coilovers - then you can adjust to your taste
    You won't regret it & it'll cost about the same in labour to fit.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    Aug 2009
    29
    Gracias for the replies. If I go with Eibach on the front will they be much stiffer and cause understeer? They seem to give the ideal 10mm drop.
    Ta.
    H
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Quote Originally Posted by Hedski View Post
    Ta.
    H
    Once mine are fitted ill let you know what their like, they are not that much stiffer mate but they are much better quality than the standard springs and do give the perfect 10mm drop.
    Im also having the RS4 rear anti roll bar fitted so that should make a massive difference aswell.
    Jan 2004
    York
    1,657
    DTM engines (as well as special edition) are part tuned by Audi to 220ps. So you will see a smaller increase in bhp and torque... up to the same as mapping a std 2.0tfsi... ie both map to the same.
    MY15 8V S3 Sportback with options
