Monster MotorsportVolks Autos
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Brake Disc height!
    Want to change thE front discs on my a4 for grooved and vented.
    My disc details are 1LA 320mm, 5 hole,vented discs with a height of 47 and thickness of 30/28
    I found these with aheight of 60 mm, so will they still fit?
    http://cgi.ebay.co.uk/A6-Quattro-4F-...item25588f2e41
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    cyrusK's Avatar
    Nov 2008
    Northumberland
    14
    Quote Originally Posted by Dazmo View Post
    What are 1LA discs? Height should be distance from hub to rim of disc. 47 mm seems more like depth of hub from wheel mounting flange(?) to disc.
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    1LA is the audi option code for my discs.
    So are you saying i can fit these discs, everything else seems the same aprt from the fact that these are 321mm instead of 320mm
    cyrusK's Avatar
    Nov 2008
    Northumberland
    14
    I'm saying that the decision is yours to make.1mm is difference over diameter.Caliper position is fixed so difference is halved in effect.Check current set-up for clearance of disc rim through caliper,how close it comes to pad locating pins,if you're happy then go back to first sentence.
