My coolant level is a bit low. Can I top up with water or do I have to use G12??
P P Crr Registered User Joined Sep 15, 2009 Messages 54 Reaction score 0 Points 6 Location NULL Apr 12, 2010 #1 My coolant level is a bit low. Can I top up with water or do I have to use G12??
B5NUT Well-Known Member VCDS Map User Joined Feb 6, 2010 Messages 5,560 Reaction score 1,606 Points 113 Location Darlington Apr 12, 2010 #2 How low? if it's just below the min, then water will be fine.
P P Crr Registered User Joined Sep 15, 2009 Messages 54 Reaction score 0 Points 6 Location NULL Apr 12, 2010 #3 Yes just below min. Is tap water ok or should I use Demin water.
B5NUT Well-Known Member VCDS Map User Joined Feb 6, 2010 Messages 5,560 Reaction score 1,606 Points 113 Location Darlington Apr 12, 2010 #4 tap water is fine.
