Monster MotorsportBadger5
Results 1 to 7 of 7
    solaris's Avatar
    Slough, Berkshire
    404
    Part Number for MFSW
    So dudes,
    I need a part number for a MFSW, now the one im after should have the alcantra inserts so it matches my gear stick and handbrake lever on my DTM.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    was one on the bay the other day, worth checking to see if its still on mate
    LOTS DONE, LOTS SPENT !!!!
    solaris's Avatar
    Slough, Berkshire
    404
    cool, thanks 1wheelonly ..... so i managed to win the one on ebay!! How lucky is that!!
    Now I understand there will be a few extra parts needed to fit it along with coding, hopefully I can use my existing air bag. I believe I will require an airbag loom? what else? part numbers appreciated.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I've got all the parts just not the steering wheel yet. The parts you need are:
    8E0 953 549 R SCSM module
    4E0 953 541 B Slip ring
    4F0 971 589 A Airbag wiring harness
    4E0 953 521 Cruise Control arm (if you want it)
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    solaris's Avatar
    Slough, Berkshire
    404
    Thanks Nathan,
    I already have cruise control factory fitted, will i still need the slip ring and SCSM module?
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Quote Originally Posted by solaris View Post
    Thanks Nathan,
    As far as I am aware you will need a new slip ring but may not need a new SCSM. You will need to look at the part numbers on them both.
    Nathan
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Check your slip ring, if it only has 6 pins which connect to the wiring harness, you will need a 12 pin version.
    Nathan
