Sky InsuranceBadger5
Results 1 to 15 of 15
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Good Friday Tinkering - some dechroming......
    In between showers I've dechromed the window surrounds using 3M Di-Noc Carbon effect film........
    Also did the boot trim.......
    And whilst I was at it I replaced the Kahn Centre caps with Audi ones.....
    Before:
    After:
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    How did you do the rear chrome on the top of the rear bumper? Mine is starting to bubble.
    Are you going to do the interior trim?
    And that really is a nice fence.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Looks really good
    (The car not the fence....)
    loves quattro
    Oct 2008
    Louth
    753
    Quote Originally Posted by Wrath View Post
    I unclipped it from the bumper, covered it, refitted it
    Nah - mine's got some nice alluminium trim which I'm happy with.
    Thank you!
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Quote Originally Posted by Richardesty View Post
    Wasn't sure if it was secured underneath so needed the bumper taking off. How did you get at it without screwdrivering your paintwork?
    Nathan
    Dec 2009
    London
    203
    that looks wicked mate, was it hard applying the film? i want to do the same with my wood trim, but dont know how to take them off LOL
    2003 Black 3.0 Multironic Cabriolet
    18" RS6s, 6000k HID conversion, Led interior upgrade.
    YE56 NDY reg for sale.
    loves quattro
    Oct 2008
    Louth
    753
    I do hope you're talking about dashboard trim and not that you've got wood trim on the outside of your car
    I don't think the trims are hard to take off, but the stuff is relatively easy to apply, I did my window surrounds in situ........
    Here's some in situ guidance: http://www.youtube.com/watch?v=Odw8Z...eature=related
    I didn't use any primer - just make sure the surface in clean
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Quote Originally Posted by drewbee View Post
    There's a few threads out there, the door bars are easy to get off, the problem one is the small piece to the right of the steering wheel. Here's a thread, although it's for the B6 I believe the trim is the same:
    http://www.audizine.com/forum/showth...r-Trim-Removal
    Nathan
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    yep the b6 is exactly the same as b7 but drewbee above, looking at his rear lights is a b6 anyway. ALSO his is a cabriolet !! all is the same except the one above the glovebox, dont try prizing that one out, there is a bolt holding the side nearest the door in, behind the end panel which can easily be removed
    LOTS DONE, LOTS SPENT !!!!
    Dec 2009
    London
    203
    thanks for the advice guys. will attemp this soon.
    so all trim except the driver side light swtch pannel can be peeled off. mines an auto - any idea how to remove the gearbox trim and front n rear ash tray? - it wasnt clear on the link.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    no drew, the one above the glove box is bolted one end. as above along with the light switch one.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I believe the gear surround should come up if you pull the gaitor carefully. The front ashtray trim has a set of grooves on the front, just separate these from the main ashtray and then slide (forwards I think) and it should come off.
    Nathan
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    I had the same problem mate, mine was also bubbling but then i bought a new one for about Ł12.00 and its easy to fit.
    Just open your boot, and very carefully use a knife or flat tool to lift it from the bumper, i covered a knife with a cloth to avoid paint damage.
    Its a ******* to remove as you cant just pull it, you have to wriggle it as it is clipped in from both sides, but once its loose it should go, then simply clip in your new one and it looks 100x better.
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    loves quattro
    Oct 2008
    Louth
    753
    Now there was a good idea for some Bank Holiday Monday activity!
    Also slipped some paint onto the rear rings...........ready to match my new front grill when I get round to fitting it!
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Hey Rich. When are you going to stop? Maybe di-noc the steering wheel or maybe the seat belts
    Nathan
