Monster MotorsportVolks Autos
    Mar 2010
    LED DRL Strip Light
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400067698888&viewitem= &sspagename=STRK%3AMEWNX%3AIT
    Does anyone have a good source, with pictures, for instructions on how to connect this to the relay? Thanks
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    What relay are you planning to connect them to?
    If you let me know where you plan to mount them (ie inside or outside) then I'll give you a heads up......
    Mar 2010
    LED DRL Strip Lights
    I was planning on mounting them outside. I really don't know which relay I should use, or if I should even use a relay. I just want them to be on when the car is and off when the car is off. Any ideas? Thanks for your help.
    loves quattro
    Oct 2008
    Louth
    753
    You don't particularly need a relay for something as low powered as LED's - you just need to connect their live connection into a circuit thats only live when the Ignition is on, however it's always good practice to install a fuse and inline switch too.
    That said - those one's don't look very waterproof....
