Volks AutosBadger5
Results 1 to 11 of 11
Thread: sidelights
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    sidelights
    hi guys,
    bought a pair of phillips sidelight upgrades and TRIED fitting them today, as anyone on here done this? (its a right t**t)
    i managed to get hold of it and twiddle it around but did,nt want to force it out. do they pull straight out? or do i need to half turn then pull out?
    dont want to damage anything so any advice i would very very much apreciate!
    thanks,
    jon
    comc's Avatar
    VW-7 Audi-1
    Edinburgh
    49
    Jon
    I have done the sidelights on my 2006 A4 avant and assuming the light units are the same, the sidelight bulbs should pull straight out. Granted I do not have chunky hands and was just able to get the tips of my fingers either side of the bulb, with just enough pressure to pull the bulb. I seem to recall some other forum members saying that they pull on the wiring as it goes into the bulb holder and that is sufficient to extract the bulb but personally I would worry about damaging the wiring.
    If your hands are too big just ask the missus to do it for you
    2006 A4 Avant 2.0 TDI (140) S-Line
    Phantom Black
    Audi Phone Prep, Bose, retrofit RNS-E, rear Parking Sensors, rear Sunblinds, Canbus friendly LED sidelights
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    ditto the above
    did mine at the weekend but replaced with LEDS
    could not quite reach or get enough forct on the actual bulb, so pulled the wire and out it popped.
    the worst you could do here is pull a wire out of the back of the connection clip - they pop back in again easily so no worries there
    NOW FOR SALE
    Audi A4 Avant S-LINE 2.0 TDI
    BOSE - PARKING SENSORS front and rear - ANGEL REMAP to 183bhp
    LED NUMBER PLATE LIGHTS, HIDS, LED SIDE INDICATORS, LED SIDELIGHTS,19x9 BENTLEY'S, S4 345 MTEC Drilled/grooved Disks -35 on H&R SPRINGS, RS4 REAR ARB RS4 Grille FULL VCDS LED RNS-E DECTANE LED REAR LIGHTS
    TO DO:
    NOTHING - Am i finished really ??
    Good 2 B A Gooner's Avatar
    May 2009
    Chichester
    715
    Quote Originally Posted by doug.p View Post
    ditto the above
    Doug - The LED sidelights, is it just a lamp change or do you need resisters etc?
    Any lamp faults?!
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    thanks guys thats helped me a lot.
    as i said all i was worried about was damaging something so i will have another go now at the weekend.
    thanks again.
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Quote Originally Posted by Good 2 B A Gooner View Post
    Any lamp faults?!
    You'll need resistors unless you buy Canbus compatible LED's with built in resistors......
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    ok getting really frustrated now! finally got one of the bulbs out today but the other one (air filter side) is not budging at all, unscrewed everything i could see near the headlight to try and take it out but no look there either! think its gona have to be a garage job now, gutted though cos i have got one side fitted!
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    pull via the wire - it will come out
    NOW FOR SALE
    TO DO:
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    thanks doug, it took some doing but both new sidelights are now in! the difference is much better so pleased with the result.
    next up phillips 5000k diamond dipped beam and upgraded fogs, if i dare!?
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    I had the same problems, eventually i ended up pushing a bulb into the headlight and now i cannot get it out.
    What bulbs did you use mate? i want some that dont cause the errors.
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    at moment just got sidelights which are phillips blue vision from autobulbs direct, no bulb out or error warnings with them and they do look a lot better than the standard bulb.
