Badger5Chris Nott
    CSK423's Avatar
    30
    Headlamp Washer Jets Stick out
    The cars had 2 new xenon headlamps under warranty and ever since then these have stuck on and off for the past 12 months.
    The car is now out of warranty and they continually stick and I'm at risk of the covers being whipped off at 70mph on the motorway after use, I push them back into place once stopped.
    Has anybody worked on these, do they simply need lubricated ???
    cheers
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Not sure if they are the same as the ones I have on my golf, but I pulled them out and lubed with WD40 then worked them in an out a few times. It worked a treat.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    hilly's Avatar
    Oct 2009
    wakefield west yorkshire
    202
    i had this problem with one side.but it went back in and was fine,i did lose the end cap and they dont come painted.i would take off the caps if you cant get them to go back in.might have frozen?
