Chris NottAH Fabrications
Results 1 to 29 of 29
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    LED Number Plate!!
    Been forver searching for a decent pair of LED number plate lights...searched the forum and found a pair for 35quid+...dont really want to be wasting the student loan on that..anyone know of any inexpensive LED's which dont throw up a error?
    Much Aprreciated!
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I believe these work without errors:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    i will soon tell you as i am fitting a set of these at the weekend
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    Quote Originally Posted by Wrath View Post
    These are the ones I have and all is well with no errors
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Yep, iv get them, real nice too!
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    Is it 12quid for the pair? or for each bulb...look quality!. Got the coming home lights on my car which also lights up the number plate..so i reckon it should change the look!
    Turkster's Avatar
    Dec 2007
    2,723
    i got a pair for my 12
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    Ordered! Thanks everyone..hopefully shud be simple to fit!
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    Got mine - same as i n the ebay link on friday
    fitted today
    look lovely
    but........
    'Rear numberplate blub' in the warning on the dash !!!! GRRRRRRRRR
    so they do not work with the B7
    i like so if i get resistors will the warning dissaper ?? anyone know? if so which ones can i get and where from ?
    i also purchased some audi compatable LED sidelights 360 degree ones as i have them in another car no probs, in this one ' sideligh' warning, so resistors needed there also
    am fitting a H7 Hid kit tomorrow........ gonna test before i go the whole hog i think, even though its 200 kit from hids 4 u and meant to give no warnings
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    mate ive just fitted some today and got the number plate bulb warning,this is a pain in arse,i ordered some normal led ones before and messed around with resistors but it just a pain in arse as you have to wire them in series.
    A4 TDI S-LINE
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    ok - time to sound thick here
    whats wire in series ??
    i have wired some resistors to my astra i used to have, it was literally a case of soldering them between the 2 wires
    how would i use a resistor on my a4 ?
    would the same apply for the side lights and things like indicator bulbs leds
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    it might be me being thick as it might be in parralel,but basically im pretty sure the resistors have to be wire like ---resistor----led------resistor----led not
    led led
    resistor resistor
    If that makes sense
    A4 TDI S-LINE
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    so one resistor across both wres on each light
    r could i soldier to the back of the bulb perhaps?
    i thought a resistors point was to trick the cars ecu into thinking there is 'load' on the wire as leds use less power the ecu things the bulb has gone due to reduced current
    so where exactly in laymens terms do i put the resistors
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    Quote Originally Posted by doug.p View Post
    The reason the warning occurs is because with a normal bulb it makes a circuit which is what creates the resistance needed for the system check. In an LED the diode doesnt make a circuit. Look closely at an LED and you will see the two pieces of metal which emit the light dont actually touch therefor no circuit is created, hence the need for a resistor
    If it's got t*ts or wheels, it's TROUBLE!
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Is the "light out warning" a standard feature?? These bulbs can't work on some cars and not others. Has anyone upgraded all their front lights to LED's?? I was looking for some front fog LED upgrades.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    Anyone know what Resiters/ohm rating we have to use to cancel the warning?
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    ditto the above
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Wonder why they work on some cars and not others, is it year related?
    Nathan
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    i am on this - started a thread about LEd / SMD
    am refitting at the weekend, have purchased a load of resistors and will let everyone know
    NOW FOR SALE
    Audi A4 Avant S-LINE 2.0 TDI
    BOSE - PARKING SENSORS front and rear - ANGEL REMAP to 183bhp
    LED NUMBER PLATE LIGHTS, HIDS, LED SIDE INDICATORS, LED SIDELIGHTS,19x9 BENTLEY'S, S4 345 MTEC Drilled/grooved Disks -35 on H&R SPRINGS, RS4 REAR ARB RS4 Grille FULL VCDS LED RNS-E DECTANE LED REAR LIGHTS
    TO DO:
    NOTHING - Am i finished really ??
    Oct 2009
    11
    tried resistors in mine they get very very hot so just by accident i wired up a 5 amp bulb extra on same circuit as number plate bulbs and no problems with warnings etc perfect no flicking and bulb not hot at all, just means a light on in boot
    A4 08 plate cab
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    Yeh i saw that on a bmw website....does the birghtness of the LED become slighlty dim due to the extra resistence?
    Yellowtrophy's Avatar
    Jan 2009
    Perth, Western Australia
    107
    Quote Originally Posted by Maq View Post
    I wouldn't have thought so....certainly no more so than if you put a resistor in parallel with the LEDs
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    just to save peole time and agro - the leds at the start of the link via ebay do not work, they give light out warnings and the seller offers no explination and no refunds or exchanges
    avoid and see my guide after sunday for working results ( hopefully ) lol
    NOW FOR SALE
    TO DO:
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,244
    I had these, didn't work on the 2007 model (even managed to break one trying to fit it), but got a refund from the same shop (f1autos) and told them they should adjust their advert saying they didn't work with 2007 models.
    Push for the refund
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    will do
    i have sent 4 emails now, i am gonna just do it via paypal
    the ad still says b7 compatable
    NOW FOR SALE
    TO DO:
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,244
    call them on the number they sent with them (not the ebay route..)
  28. #27
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    got a reply saying to post back for a refund ! which i have done
    got me some other ones now - over on my LED thread
    NOW FOR SALE
    TO DO:
  29. #28
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,244
    nice one
  30. #29
    alpesh26's Avatar
    Mar 2011
    270
    I managed to fit my number plate LED's this weekend. I managed to get round the error on the DIS by fitting resistors to the bulb holders (although is does beep when I turn the car on but the warning goes away straight away), my set up is:
    One 150ohm resistor on one of the bulb holders
    and
    One 100ohm resistor AND One 120ohm resistor on the other bulb holder.
    The problem is, the one with the 2 resistors on is dimmer and has more of a blue tint than the one with one resistor (probably due to the current the resistors are drawing).
    Which resistors did you guys use? I've only spent £2.75 on this mod so far so I should have some budget for more resistors ! I havent bothered with heatsinks and things, drove around for an hour and a half with the lights on and nothings melted.
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
