Volks AutosEM Tuning
Results 1 to 7 of 7
    May 2004
    10
    A4 1.6lt Engine comments
    I would like your comments on the 1.6l 8valve engine that the A4 carries with.
    Regards [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    imported_dumpvalve
    Re: A4 1.6lt Engine comments
    Not stong enough for a car of the A4's weight. I thought the 1.6 was 16 valve? Maybe I'm wrong. But a 1.6, whether 8 valve 16 valve or whatever is not really the engine of choice. Even just a 1.8 would be much better.
    Drew.
    Mar 2004
    North West & Sweden
    211
    1.6 developing 75 kW (102 bhp), 148 Nm. 0-100 km/h: 12.6 s; top speed: 190 km/h
    OMG, i hadn't noticed that engine was an option! Whoever suggested installing that relic in the B7 should be shot.
    imported_apcourtenay
    i've got a 1.6 b5 and it's not too bad once it gets going, good for economy. but its quite fruhstrating at times when you could really do with a bit more power. mid-range is fairly good and not too bad at pulling off due to the low gear ratios in 1st and 2nd!
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    in the a3 fwd i'd think it'd be ok, but in an a4 thats asking a lot from a 1.6, i'm sure it'd be put under a lot of stress with passengers
    why not go for a tdi? or 1.8 if going for a4
    tdi will be much cheaper if you do a lot of miles in and out of town, if you only have it for the 5 min shopping run once a week, thats different
    imported_Macduff
    [ QUOTE ]
    i have seen many new a4s now, but i have never seen a 1.6 one yet and im shocked to find out that they actually do one, its just good to see that no-one is wasting their money buying one of the underpowered cars, the resale value of the car would drop like a stone!
    [/ QUOTE ]
    I'm sure they're sold. People buy these to get the badge just like BMW 316i. The resale value is as good as any A4
    gizze's Avatar
    Dec 2003
    Norfolk
    615
    The 1.9tdi is only just over a grand more and I bet it would be worth 2 or maybe 3k more after 3 years so you may find it is actually cheaper monthly than the 1.6.
