PLEASE HELP!!!!!!!!!!
I have purchased an Audi CD Changer to fit into the glove box, but have an issue with the wiring to the connector at the HU end.
A4 S-Line 2006
I purchased the BUS Link cable which will not work the Changer.
I modified the HU end and fitted mini-resepticles into the vacant 8 ports at the Concert HU end. Having replicated what cable was fitted to the original connector block, I then placed new resepticles into the HU Block.
Having read the wiring diagram, I found that the "Power Ground & Audio Ground" were fitted to Port 18 of the HU connector. (Follow Link for Diagram and scroll at bottom left for correct diagram.)
I assume the Power Ground should be independant? if so, where can it be relocated.
www.conofrei.com/service_MANUALS.html
Regards
