Volks AutosSky Insurance
Results 1 to 10 of 10
    Jul 2009
    S-Line 2.0TDi PRNDS Problem - All letters highlighted
    Hi
    I have an A4 Avant 2.0TDi Auto S-Line on a 55 plate with 127k on the clock. It has been serviced by Audi since day one, and I have recently noticed on my dash that all the letters on the PRNDS transmission indicator are often highlighted in red. I should say that nothing is flashing at this point (which I believe is another problem owners have experienced and has proved to be an expensive repair). This issue is an intermittent one and often the display reverts to the correct display - i.e. 'D' for drive.
    Just really wanting to know if anyone else has experienced the same problem, and what the likely cause of this is. I am wary about putting it into a garage (especially at this time of year) until I have some background on the problem, as I suspect they may tell me the worst case scenario and charge me a fortune (1500ish in some cases) to repair it.
    Is there software available that I can install on my laptop, where if I purchased the cable it to connect it to my car would tell me the exact problem?
    Thanks in advance
    Pat
    sebhar70's Avatar
    Apr 2009
    South London
    200
    I have the same problem on my 2.5TDi Multitronic 02 plate (85k) Took the car to Bexley Audi they did a diagnostic which showed up nothing, the engineer stated that this happens from time to time with multitronic gearboxes possibly due to lack of gearbox oil change (due every 40K) bad oil can increase wear on gearbox components, suggests I get the oil changed (160) should resolve issue, if not worse case scenario is the gearbox ecu rebuild (900+) Ebay company http://ecutesting.com/audi_a4_a6_mul...c_gearbox.html do the refurb for 350 + what ever you pay to remove/reinstall gearbox. When I said worse case scenario I did'nt mention full gearbox rebuild/replace at the fantastically low price of 3500
    Lets hope yours and mine just need the oil changing (I'm assuming that you have the multitronic gearbox)
    Get your car vag-com first and see where you need to go from there. Check vag-com section of forum there should be someone in your area whose got the cable and software alternatively a local specialist will probably do a scan for a drink.
    Jul 2009
    Had my car in to get checked out today at 'A for Audi' just outside Glasgow. As suspected it's the ECU with the fault code G196 referring to Speed Sensor 2. The gave me a quote of 1,112.73 to replace the ECU. This is broken down as follows:
    647 +VAT for the ECU
    100 + VAT for the Gearbox Oil
    200 +VAT for the labour
    Anyone had to replace one of these before? Is this a typical quote for this type of repair? It's a bit stiff the week after new year to get a bill like that, so any cost saving advice would be appreciated.
    Pst
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    I don't quite understand. Is the ECU broken or the speed sensor? I know that the faulty speed sensor is common and can be replaced. I think that Audi had a recall in USA in 2009 to change that sensor.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Jul 2009
    Not sure. They told me I needed a new ECU as they tried to reset it several times to no avail. When I asked for a fault code they told me that it flagged up 'G196' which is the code for Speed Sensor 2.
    I'm confused!
    27,028
    Get someone to scan it with vcds before anything else to check the faults logged then you can investigate further yourself & maybe try finding a 2nd user ecu cause thats what 800 or so, sure you can find it cheaper.
    Jul 2009
    ok, the 2nd user ECU thing is something i have thought of as that is the bulk of the cost. This might be a really silly question but are all ECU's on B7 2.0TDi's the same?
    Also - I know it's a complete lottery, but would anyone use ebay to purchase something like a a 2nd user ECU? Found this one on there - says it's only done 20K:
    http://cgi.ebay.co.uk/AUDI-A4-ABS-PU...item35a60e23e3
    Let me know
    Pat
    27,028
    You need to grab the part number fo yours via a vcds scan then have a look & no reason why you cant get of ebay, certainly cheaper & have had no problems with ebay purchases mostly, plus have 60 days or so to make a claim if any issues with parts.
    Jul 2009
    A year and a half later, and this problem has come to a head. Despite the PRNDS light intermittently flashing the car has been driving ok, but now the symptomatic effects are starting to happen. I've been occasionally losing reverse gear and sometimes all power in the accelerator goes. Had it rescanned and the same fault codes are appearing - G195 & G196 which are errors coming from the speed sensors. So still not even sure if its the ECU or just the speed sensors. Is there any way to tell? And can speed sensors be replaced or even just cleaned?
    Anyway, looked into a replacement ECU and managed to get the part number for my ECU from the supplier of parts for Glasgow Audi (Glasgow Audi said they werent allowed to give me the part number but their parts supplier might be able to). So I called them and they asked for my reg number and from that were able to tell me that my multitronic gearbox ECU part number is 8e0910157h. Is it this number that i need to match up with any replacement ECU? If i get a replacement ECU with this part number will it still need recoded?
    I'm not keen on getting my own ECU taken out and sent away to a repairer and have it rebuilt/refurbished as this will result in my car being off the road for 1-2 weeks which would be a real inconvenience, so looking for an 'out and in' solution if possible by sourcing a replacement. Just need to know all the pitfalls before I make a decision. There are a few companies out there selling ECU's with matching part numbers but I need to know if this is as straight forward (out and in) as it sounds.
    Mar 2011
    East Mids
    452
    B6 S4 4.2 V8 SILVER SALOON - BEIGE ALCANTARA - BOSE SYMPHONY - DRILLED/GROOVED FRONT DISCS
    FOR SALE: £6750ono
    Previous Cars
    .:R32 MKIV 3DR Pearl Black (Awesome car), Lexus RX300, Lexus LS400, Mitsubishi Shogun Sport V6, Audi TT Roadster 225, Range Rover Vogue 4.6 V8, Mazda RX8 231, Peugeot 307 CC 180, Subaru Impreza WRX 2.5, BMW520i, Lexus IS200,Golf GTi MKV, Audi A4 1.9TDi 130
