This is the anti roll bar drop link fitted to the front multi link suspension and fastens to the lower front straight control arm.
If the garage is saying they need replacing it is because the rubber bush in them is worn so the front end should feel a little more sloppy than normal. No big deal but I would get them done.
Only about £20 a piece and should take no more than 30 mins to do each side. Just depends how seized the old ones are! mind you if you have a blow torch then you will be fine.
