AH FabricationsJMB Retrofits
Results 1 to 18 of 18
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    Buying 55reg 2.0tdi s line
    Hi im probably going to buy a 55 reg 2.0tdi s line on sunday is there any major faults i should look for, also he says his glove box is faulty saying the hinges have snapped is this a common fault and easy to fix cheers in advance dan
    A4 TDI S-LINE
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    have same problem my friend with glove box, hinge on the right as completely snapped! only had the car a few months so not a good start, have,nt had time to look about for how to fix/replace yet but will let you know when i do.
    or yeah same model aswell, 55 plate A4 s line tdi.
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Check the engine code, if it is a blb I would stay away unless it has had the chain oil pump assembly changed to a gear one. They have balance shaft and oil pump issues.
    Glovebox's always snap, check in the b6 section for a fix, or shell out for a new lid for 90 or so or a whole new glovebox 170 odd.
    The arm rest's also snap their handle.
    Good 2 B A Gooner's Avatar
    May 2009
    Chichester
    715
    Quote Originally Posted by jwhat View Post
    Stay well away from BLB engines as said previously - Big money to fix... Check in the service book for the engine code or in the boot where the spare wheel is.
    Apart from the glovebox issue - Also watch out for loose door handles - Drive you mad!
    Good car though, great mpg (i get 45/48mpg) and as quick, probably quicker than my old 1.8T A3
    S3 NIK's Avatar
    Mar 2007
    190
    Fairly recently bought an 1.9TDI A4 avant 2008 '57' from a main dealer to ferry my dog and mountain bikes around, is this likely to be a BLB, if so i'm going to rip into my suppying dealer if it a known problem.....
    Where do i find the engine code?
    2008 A4 Avant Sline. Sat nav, MFSW, Privacy glass.
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Don't worry, the blb engine was only 2.0 and in the early cars i.e 2005.
    Good 2 b a gooner: The door handles can be fixed pretty easily, I only found out this after one of mine fell on the ground and boke off some paint!!!! GRRRRR
    Oct 2003
    South Wales
    2,942
    Quote Originally Posted by S3 NIK View Post
    As jwhat says, yours is a later car so you won't have the BLB Engine.
    Mine is a 2006 06 plate and it has a BRE engine, so yours should be ok.
    Dolphin Grey Audi S3 8P
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    cheers for the input guys i bought the car today and i love it,its a bre engine so good news i guess,only problems are glove box and cigarette lighter socket doesnt work,sat nav charging etc.
    A4 TDI S-LINE
    May 2009
    Chichester
    715
    Quote Originally Posted by danotto View Post
    Prob just a fuse mate.
    Congrats
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    the light is on on the cigarette lighter but wont charge anything,oh and noticed drivers door handle cover loose how do i fix this cheers dan
    A4 TDI S-LINE
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    me again,just wondering how do i turn passenge air bag off, the owners manual says there is a key slot in the glove box but where the book shows the switch my car just has a blank slot
    A4 TDI S-LINE
    May 2009
    Chichester
    715
    It was an option before 2006 i think, so probably doesn't have it.
    If you want Isofix it's an easy retro fit - I done it myself, took me 5 minutes.
    The light in the 12v socket won't work off the same fuse - Try changing the fuse before ordering a new one.
    As for the door handle, i glued it back, but need to do it again....
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    cheers buddy where did you get the isofix airbag switch from ill check the fuse now cheers dan
    A4 TDI S-LINE
    May 2009
    Chichester
    715
    It was just the anchor point in the back i fitted - Cost 40 from Audi. Not sure if you can retro fit the front off switch? Give your local main dealer a call, they'll know more.
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    cheers any idea of how to fix my rattling door handle cover
    A4 TDI S-LINE
    May 2009
    Chichester
    715
    Door Handle
    I'm going to start charging....
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    cheers bud just glued it back on with trusty dow corning hopefully it works
    A4 TDI S-LINE
    Six-speed's Avatar
    May 2009
    27
    My fag lighter didn't work, was just the fuse. Think light is on different circuit that comes on when lights on.
    05 A4 2.0TDi S-Line Avant
    BOSE, cruise, ambient light, steering wheel, seats and an engine!
