    7
    A4 B7 2.0TFSI S4 EXHAUST TIPS *HELP*
    Hi any1 know where i can get a set of b7 s4 exhaust tips to fit my b7 2.0tfsi s line i currently have a full milltk but want to change the diffuser to s4 and change tips to match
    also any pics with this done thanks
    Yellowtrophy's Avatar
    Jan 2009
    Perth, Western Australia
    107
    The S4 has 4 pipes coming out of the rear box, 2 each side. The 2.0T only has 1 on each side, so it is not a case of just swapping the tips.
    You would need to find an aftermarket 3rd party manufacturer of tips.
    7
    i know that why im changing the diffuser to fit the twin tips they also have a bend in them too and thats why im asking if any1 knows where or if i can get some replica type ones anywhere thanks anyway
    Jan 2009
    107
    Not cheap, but these are your best bet.
    http://www.custom-chrome.co.uk/shop/...products_id=45
    I looked at doing this when I had my Milltek fitted, but then decided the larger 100mm finishers on the Milltek looked good enough...
    7
    yeh they look ok thanks
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    You could get some welded on to replace the standard item... try Powerflow or a similar company.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
