Badger5Chris Nott
    Mar 2006
    England
    Funny noise when turning right
    Hi I have an A4 special edition 2.0T and have noticed a bonk/ clicking noise around the front left corner when turning right at slow speed. Any Ideas? I hope it is not the CV joint! What else could it be? I didnt notice any noise under acceleration or going around a roundabout.
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    Drive shaft or top mount
    If it's got t*ts or wheels, it's TROUBLE!
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    I have the same car and mine was doing the same recently so put it into dealers and they replaced lower/steering arms i think. Not exactly sure what they replaced, but it stopped making the noise. It was on warranty so did'nt cost me anything. If still under your warranty just get it booked in at Audi.
    27,016
    Turn left then
    Andy D's Avatar
    Sep 2007
    Inverkip, Scotland
    276
    I'm getting this too, knocks when on full lock in either direction and I get a clunk from the driver side front wheel when going over small bumps slowly.
    Had an independant garage check it out today, he spent ages in there with a nail bar, then a stethoscope and had a test drive, he finally said he thought it was the lower something or other arm....
    He pointed out a thick alloy arm at the lower end of the suspension which he said he could try changing the bush in but recommended changing the whole arm.
    I'm still in two minds whether to go to the dealer to have them diagnose the fault, then go back to the independent to have the work done....
    B7 A4 2.0T S Line special edition Quattro Avant.
    Bose soundsAngel remap.
    Alu mirrors, blue vision sidelights
