Sky InsuranceBadger5
Results 1 to 13 of 13
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    Question re cruise control retrofit
    Hi All,
    I've gone through all the cruise control threads but just wondered if anyone has installed the control stalk and not need to re-code? I did the installation before on a golf and didn't need to. I've ordered the bits form the A4 and hoping that I might luck out again!
    Cheers,
    Bing
    2005 A4 S-Line B7 2.0TDI PD140, Pearlescent Garnet Red. Bluetooth, BNS 4.2 Sat Nav, Colour DIS, MFSW. Retro'd: Cruise Control, Ambient light, Dension Gateway CAN Enabled Ipod Interface
    2003 VW Golf IV Highline TDI PD100, Metallic Silver. Bluetooth, Fogs, Sport Seats, Air-Con, Trip Computer, iPod Interface, 18" RS6 Alloys, Colour Coded Bumper Valences, Retro'd Cruise Control.
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    I'm pretty sure you do need to but sure if you out it all in and it doesn't work just get it coded another time? And hopefully you won't have to recalibrate your steering sensor.
    Do you have VCDS/vag-com?
    I'm a bit far away to help but I know there are a few people around who could help you.
    Oct 2009
    166
    I recently had it fitted to my B7.
    The lad that fitted it had to hook the car up to the laptop and re-program in what features the steering wheel had, never new you could get a heated steering wheel!!!
    Oct 2009
    166
    By the way for anyone wanting it fitted by the professionals i would recommend these..............
    http://vwcruise.com/
    Cost me 240 including the replacement steering column trim with the cut out for the cruise control stalk.
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    cheers boys. I've got my emissions light on at the moment so need to get that looked at. Plan is to get them to code it then should it not work right out of the bag. Got all the necessary bits for the tidy sum of 70 on ebay.
    Southend
    First post, and I can +1 for vwcruise.com.
    They fitted cruise and changed my center console to get rid of the phone cradle on my newly acquired 2.0 tdi s-line. It looked enough of a faff that I was glad I didn't do it myself.
    Steve.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    for what vwcruise charge you could purchase VAGCOM from NHN, a trusted member on this forum, then purchase the cruise control off the bay for pitence and fit it yourself, its a really easy mod.
    that way you would gain by having the knowledge of doing it and still have your own vagcom which is priceless.
    LOTS DONE, LOTS SPENT !!!!
    Sep 2005
    Worksop, Notts
    97
    Was 240 with or without changing the steering wheel control unit?
    Oct 2009
    166
    Sorry, i dont know what a 'steering wheel control unit' is?
    It was a audi kit in a box, he fitted it, hooked up the laptop and hey presto!!!
    Give them a call, they are very approachable and know there stuff.
    Yes if you can do it yourself its cheaper but then again places like Fontain want nearly 400!
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,537
    Quote Originally Posted by jaygeezer871 View Post
    It's the electronic control module that fits around the steering column, and to which all the column and wheel mounted switches connect.
    Its proper name is Steering Column Switch Module SCSM.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    Hi Guys,
    just got my bits for the retrofit but it doesn't include the 2 screws listed in its contents. Does anyone have the spec for these so I can pop to a parts place and get them?
    Cheers,
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    pm pjmspeedy, got mine from him, he will know the part number
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    Cheers. Came across the parts on another thread. Now to see if the local dealers have it in stock :-)
