Results 1 to 14 of 14
    Nza
    Nza's Avatar
    UDO Unidentified Driving Objec
    May 2009
    Earth
    32
    Urgent: What Brake Pads Would you recommend for Audi A4 S Line Sport
    Hi
    I just recently had the break pads worn display on my display unit yesterday.
    What break pads would you guys recommend and a source to buy which is within budget and of the sporting break pad type.
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Yeah get some EBC REDSTUFF PADS mate
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    M7R
    Type Approval Engineer,
    Sep 2008
    Chilwell, Notts
    212
    unless you are going mad, OEM. but if you look at your old pads they should say something on the back, imbossed into the back plate like Textar 4532 or something, just look for the textar in that material code, or who ever makes it... but tbh thats prob a bit too in depth, in which case just get them from TPS / dealer, dont be tempted by some budget pads, aas unless you know what you are looking for ie the approval numbers and material codes + brands you could get some very average pads that just pass reg90 or you could get some stonking ones.
    ebc red stuffs will be ok but no real advantage over oemand could have a slightly numb feel when cold, like yellow stuff. unless you will be getting the brakes hot I would stick to either oem or poss green stuff pads, green stuff is lower dust and kinder to discs BUT you must bed it right, ie give it a bit of stick but not really hammer it but like wise dont be girly with it, as green stuff bedded wrong is ok, green stuff bedded right is brill!!!
    83 GTi - road legal track weapon - now running 2.0l 16v super charged, = FAST!
    Daily hack: Audi A4 Avant S Line 2.0TDI Motech map to 175bhp, Milltek twin exit system, 1/2 leather, DIS, Fan washer jets, B8 rear aero wiper, FK headlight,
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    EBC redstuff. Superb even when cold and out of this world once hot. I recommend drill/grooved discs too. Never ever fade and I track mine
    If it's got t*ts or wheels, it's TROUBLE!
    Mar 2009
    Stevenage
    289
    Quote Originally Posted by M7R View Post
    We've found our brake pad geek lol only joking!
    M7R
    Sep 2008
    Chilwell, Notts
    212
    Quote Originally Posted by TorqueTerrorist View Post
    I know a bit, not everything but more than the average joe, as my job is type approval, so I witness and carry out reg 90 replacement brake pad approvals, I have seen some very very good materials from some very obscure makers, and I have also seen some average materials too, and very rarely some very poor ones that dont make the grade.
    Oct 2009
    Athens, Greece
    42
    Hi! Ive got an s3 8p with grooved ebc discs and yellowstuff, they make a hell of a noise when I decelerate from say 130mph .... like an airplane.... suspect that those are the grooves tof the discs but just wondering if anybody else is experiencing that airplane like decelerating noise? Looking into getting something like these below.... have to find out if they'll fit first...
    http://cgi.ebay.co.uk/AP-Racing-4-po...item3a5048a997
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    I have BEC REDSTUFF pads with standard discs and braided brake lines, great setup much better than standard but couldnt find any grooved discs to fit my car as they dont seem to make any for the 3.0 Quattro, so im probably losing abit of performance there.
    Marc1's Avatar
    Feb 2008
    720
    Quote Originally Posted by Dazmo View Post
    I beleive your front discs are the same size as the 2.0TFSI, so you could always try searching under them instead, but just check they are the same size first.
    For Sale
    B6 S Line Saloon rear bumper,B6 A4 Upper Grille,B6 1.9TDI catback exhaust,B6/B7 Full Piano black inlays,B6/B7 RNS E/GPS Sharkfin,B6/B7 Side airbags,B7 2.0TDI Intercooler and MAP sensor
    Marc1's Avatar
    Feb 2008
    720
    Thought EBC pads Green, yellow or red where all recommended based on power output, so yes the Redstuff may be fine for those with the 2.0TFSI and 3.0TDI as they're above 200BHP, but the OP hasn't specified which A4 S Line they have, so if it's a 2.0TDI the redstuff will ber overkill and will not work as well.
    For Sale
    Mar 2009
    Stevenage
    289
    Quote Originally Posted by S3GG View Post
    Me and you both pal. I hit them off the 155 limiter today and it sounded like I was drilling fro oil lol they work again for the round about though, wicked brakes!!
    Mar 2009
    Stevenage
    289
    Quote Originally Posted by Marc1 View Post
    Im sure greenstuff would be good enough but also they recommend redstuff for the larger car so I guess it's down to how hard it'll be driven
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    My front discs are approx 320mm and have front S4 calipers
    Marc1's Avatar
    Feb 2008
    720
    Yes that's right same as the 2.0T then - 320mm discs and S4 calipers. Seems you B7 drivers got a decent brake upgrade over the B6's.
    For Sale
