Volks AutosChris Nott
Results 1 to 12 of 12
    91
    de ambering my headlights
    does anyone have a diy thread on how to remove the egg yokes from my headlights?? want to clean it up a bit!
    91
    thanks jwhat. gonna take a bit of time to build up the courage to do this!!
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    I'm going to have a go at this when I do my cam belt. The whole front end has to come off anyway.
    Also, just a thought.... I might smoke the lens out alittle and see how that looks instead of bashing the lens off right away. I had a diesel before that had clear lenses, they'd look better also but I bet you can't just by clear lenses
    If it's got t*ts or wheels, it's TROUBLE!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    Quote Originally Posted by TorqueTerrorist View Post
    just take the orange out and use stelth bulbs
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    There are a few late-spec sets on eBay if you want the proper OEM versions - 70 each side approx
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    Mar 2009
    Stevenage
    289
    Quote Originally Posted by ultramodz View Post
    Mine are xenon though
    Mar 2009
    Stevenage
    289
    That was the idea but you need to smash the crap out of it. Don't want to ruin it
    Nov 2003
    London (N8)
    515
    Here you go...
    http://www.audizine.com/forum/showth...enon+headlight
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    A few months later and I'm going to try to de-egg this weekend.
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Did the Clear corner mod at the weekend, used the following two guides
    Bumper one: B7 A4/S4: Clear Corner Mod/Removal of Bumper
    Clear corner one (no drilling/hammering): DIY: CC (Clear Corner) Mod
    When I was doing the clear corner bit, I couldn't get the heat gun to work so I put my headlights into the over. I tried 50 deg C for 5 mins but it didnt soften the glue enough, I then went to 75 degrees C for 5 mins and they came apart with a bit fo help from a flathead screwdriver. The other thing I did differently was to use a really thin t20 screwdriver I had lying about to take out the screw behind the chrome housing, it was a bit small for the screw(it's a t25 I think) but the screw came out alright and didn't slip too much and I would have been stuck without it as a normal screwdriver would have been too thick.
    All I need is some chrome bulbs, so can anyone recommend some? and also what size are they? They look like opposite pin p21w / 382 but most auto bulb websites say py21w fit!!
    Really glad I did it, the front of the car looks much cleaner now.
    bez101's Avatar
    Jul 2008
    8,510
    stelth bulbs like i posted b4
    theres alover the bay
