JMB RetrofitsBadger5
Page 3 of 29 FirstFirst 1234567891013 ... LastLast
Results 81 to 120 of 1140
Like Tree16Likes
Thread: 2.0 TDI oil pump / balance shaft failure?
  1. #81
    7
    Hi i'm due to pick up my a4 sline 2.0tdi on a 55 plate (reg 2006) does anyone know if this car will be affected by the blb, brb engine. Really concerned at the moment about the engine if i should now buy the car any quick replies would be helpful
  3. #82
    Dec 2008
    32
    P Crr - If you give me the VIN number I can check fairly quickly as I have access to a copy of ETKA and am happy to do so. Also, the V5 will tell you.
    BRgds
    Al
  4. #83
    Sep 2009
    54
    WAUZZZ8E36A101***
  5. #84
    Dec 2008
    32
    Sorry but I need the last 3 digits as well - if you can send me those to my e-mail - albarker01@aol.com - I can give you an answer straight away. Otherwise ask the seller to look at the V5C Registration document and give you the engine code & number - it is certainly listed on mine.
  6. #85
    Sep 2009
    54
    WAUZZZ8E36A101308. Its not the person who is waiting to pick up car. I already own this car but would appeciate knowing whether my car has the potential of the chain problem.
    Thanks.
  7. #86
    Dec 2008
    32
    P Crr - It is more than likely you have a BPW engine code and, therefore, the spur gear oil pump drive - so you should be OK!!
  8. #87
    Sep 2009
    54
    On the sticker in the boot it says engine / trans code BLB
  9. #88
    Dec 2008
    32
    P Crr - Disregard my last post. Having checked your VIN against ETKA, you have a BLB engine but it is fitted with the spur gear drive. It would appear that all BLB engines fitted to cars with a VIN after 8E*6*080172 were of the modified type. Hope that helps
  10. #89
    Sep 2009
    54
    Thanks vey much. I have been really concerned with this ever since I seen concern on forum. Bought car wanting to keep for a while but had thought of selling. Looks like I can keep it know.
  11. #90
    Dec 2008
    32
    I would, however, caveat my comment below by saying that it would appear that you have the spur gear type of oil pump drive. My comments are based on ETKA information from v7.0. To be doubly sure, I would ask the question of Audi, giving them your VIN number and Engine code and serial number and formally posing the question to them. Not trying to wriggle out but I don't want to say you have the modified drive mechanism and it fails and it is found to be the chain drive version because mine is a BLB (earlier 55 plate Sep 05) with the chain drive which has failed!!!
  12. #91
    Good 2 B A Gooner's Avatar
    May 2009
    Chichester
    715
    My neighbour has taken my engine code into work(He works for Audi), and told me my car isn't affected (It's a 54 reg 2005) as it has a chain, but not a cog and chain. Apparently chains are ok, unless they have cogs also?!
    Not sure if he's got confused...!
    Thoughts guys?
  13. #92
    Sep 2009
    54
    How do you get the ETKA info?? I have heard elsewhere that only certain chassis numbers are affected.Albarker01 did your chassis number on ETKA say you had a chain or gears?
  14. #93
    51
    what is ETKA
  15. #94
    7
    wauzzz 8e16a180087 got bre also on the same page its written as so BRE --- HCF does this mean probably ok its not the BLB engine many thanks...
  16. #95
    Dec 2008
    32
    Am answering a few posts in one here! I think your neighbour is confused! There appear to be 2 types of oil pump/balance shaft drive, namely: chain drive with sprockets (cogs?) and spur gear (like a gear box). Earlier BLB engines had the chain drive whilst older BLB models had the spur gear, according to ETKA, which is the VAG (Audi, Skoda, SEAT & VW) electronic illustrated parts catalogue and can run on Windows OS. If you search that popular on-line auction site you may find copies available! The good thing about ETKA is that there is an option to tailor the search according to your VIN; ETKA automatically comes up with all the relevant parts for your model. Very useful. When I plugged my VIN into it, it certainly identified my engine as being a BLB (the vehicle log book - V5 - also tells me it is a BLB) fitted with the chain drive, so ETKA was correct for me. Tom Green 78 your VIN seems to be missing a digit! Hope this helps guys.
    Last edited by albarker01; 30th January 2010 at 10:50. Reason: grammar, spelling!!
  17. #96
    51
    cheers albarker.
    I bought elsawin, is that more or less same thing.
    Incidentally I have now bought all bits and bobs incl the chain and tensioner, and also the timming belt and kit, water pump , also some tensioner tools. I thought i had ordered the locking tool kit but mix up in communications and somone sent the tools i thought I could do without. (will sell them on ebay once complete) This afternoon we start!!!! god help and bless us!!!
    I will take some pics and videos and add to facebook site if anyone want to see. will let you know how things go on monday.
    also hired an engine lift for 35.
    Anyone here got any tips before we start?
  18. #97
    Dec 2008
    32
    Weggie - ELSAWIN is the Maintenance manual (which does have a link into ETKA), another very useful tool especially when you are embarking on something like your job. I secured access to both and found them very descriptive with good diagrams. A much better workshop manual than the old Ford Cortina one my dad had which went something like: 1. Remove propshaft, 2. Remove Gearbox, 3. Remove Engine!! Think you just need to support the engine whilst you work on the sump area. Good luck with the job and can't wait to hear about the successful first start post repair!!
  19. #98
    7
    all the numbers i can see in my servive book are as follows - VEH DATA wauzzz 8E 1 6A180087, MODEL DEES 8ED OJC 0237260 , A4 AVANT TDI2.0 R4 ETC ETC IF YOU COULD HAVE A LOOK IN YOUR ETKA BOOK MANY THANKS, BRILLIANT CAR BY THE WAY.........
  20. #99
    Dec 2008
    32
    tomgreen78 - According to ETKA that I have access to your VIN data says you have a BRE engine (which has the spur gear balance shaft drive) and HCF gearbox. Your V5 should also state your engine number. I would recommend you double check with Audi that the drive is that type.
  21. #100
    Sep 2009
    54
    How do you use ETKA. When I look I find a chain on oil pump??
  22. #101
    Dec 2008
    32
    P Crr - At the Audi option start screen in version 7.0 at the top of the screen in the middle there is a box that is entitled FI Search. Type your full VIN into that box and then hit return. A pop-up Car Identification screen will appear giving you all of the details of your car (including engine, transmission & final drive codes). Hit OK at the bottom of this pop-up and you will then have an EPC tailored to your car - you can seen the VIN muber etc at the bottom of the screen as a check. If you then go to the Main group selection and click on Box 1 - Engine - you will get your specific Engine part numbers etc. If you scroll down that first page to MG1 SG15 you will see your oil pump option (Illustration 115-51). Double click on that line and you will then be taken into the exploded view of your oil pump and associated components. It is on this screen that you see the spur drive balance shaft.
    Hope that helps
    Rgds
    Al
  23. #102
    Sep 2009
    54
    I can see the spur drive balance shaft on 115-51 but my log book and sticker in boot says BLB. Why am I not supposed to select 115-35 as this states BLB. If I select this then my car has a chain.
  24. #103
    Dec 2008
    32
    P Crr - Check your VIN with the data given in ETKA. For VIN to number 8E*6*080171 the BLB engine has a chain drive (diagram 115-35), for VIN 8E*6*080172 onwards the BLB has a spur gear drive (diagram 115-36). When I put your VIN into the ETKA I have access to, it comes up with the spur gear version.
  25. #104
    51
    Just to let you now I have been working on the car on sun and today. My friend knows about cars so he lead the work and we decided to change the chain as well as the timing belt. Fairly big job, it took 4 to 6 hours to get the front end off, ( there lots of thiong in the way to even gert this off so you need to be patient and strip things one by one) I am glad my pal was this ggod!!!
    Then we had to take the sub frame off to get access to the sum, this meant an engine lift. Trouble was the one we hired was broken on Sun, it kept dropping, we had to give upon Sun. It took 2 hrs this morning to get the right one, we lifted engine and eventually exposed and striped timing belt and changed the water pump, this allowed us to get the sump of, Note there is 2 bolts at back of engine that took a long time to get off, you need special allen 5mm key with ball end to remove, but it has to be long,( we wanted an hour buying this). We got off exposing the chain. yes the tensioner was broken, just like previous pictures i have seen, plastic bit broken off and in the drained sump oil. The chain was slack and could be removed from the two cogs, but we could not get the new chain over these cogs, so this shows the stretch, hence the rattle. I guess this could break causing serious damage. The bottom cog was worn but we had a new one, the top cog ( the difficult one to remove was fine).
    I have photos, but not sure how to add on site.
    The problem we then had was that the 4 bolts holding the cog in place were utter rubbish, we split the head with wrench of each one, really soft metal. I called Audi and they had 2 bots in stock!!!. 35 p each!!, ordered 8 and will try to complete next week. We abandened the work, bolted up engine so i can de-hire the 38 engine lift per day.
    And will try to finish next week. Will have to grind off the 4 bolts, bugger, may have to tap them!. But this cog has to go , it's worn
    After that, sump back on, then complete timing belt, then put everything back together. lets hope we have not lost bits.
    Note you need new engine coolant &, engine oil say 65, also the air conditioning unit needs re-charged with gas, about 50. Also power steering fluid, this is about 18.
    You also need patience, and time.
  26. #105
    Sep 2009
    54
    Thanks Albarker01. I dont think i am using ETKA correctly. Is it supposed to work via internet?
  27. #106
    Dec 2008
    32
    As far as I am aware, you can only get internet connection if you are a subscriber but that is about as far as my knowledge of the system goes.
  28. #107
    Sep 2009
    54
    What verson off ETKA do you have. Mine does not show 115-36. I have version 7 update 597.
  29. #108
    Dec 2008
    32
    Version 7.0 update 711
  30. #109
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    Just geting back to the oil pump / balancer shaft issue. I was speaking with a local Audi service manager and asked if they've hade any failures. He said to me that they've had to replace a few, the last 2 at approx 70000miles. I'm very worried about mine now and asked if Audi were doing anything about it. He said that they won't touch it!
    I'm going calling Audi Ireland!
    2005 A4 S-Line B7 2.0TDI PD140, Pearlescent Garnet Red. Bluetooth, BNS 4.2 Sat Nav, Colour DIS, MFSW. Retro'd: Cruise Control, Ambient light, Dension Gateway CAN Enabled Ipod Interface
    2003 VW Golf IV Highline TDI PD100, Metallic Silver. Bluetooth, Fogs, Sport Seats, Air-Con, Trip Computer, iPod Interface, 18" RS6 Alloys, Colour Coded Bumper Valences, Retro'd Cruise Control.
  31. #110
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    The AUDI Ireland guy was absolutely no help whatsoever, "I'm the VAG customer service head and if I've not heard about a problem, it doesn't exist" blah blah blah. Called AUDI UK then and they at least logged my concern in case it happens to fail.
  32. #111
    14
    Quote Originally Posted by albarker01 View Post
    Hi< I am about tp pick up my new A4 (2005 55-reg BLB engine code 2.0TDI SE) on Tuesday of next week, I have paid a deposit. Would you be able to check my VIN against the databse you have there? It would give me some ammo to go back and check with the dealer so I can highlight the issue and check the car before I pay what is a lot of money to me. I thought buying an Audi would give me piece of mind on the quality stakes, wish I had seen this thread before I paid a deposit.
  33. #112
    Dec 2008
    32
    PhilA4 - I am more than happy to do so but I would caveat my response with please double-check with Audi as cars/engines may have been modified since initial build and ETKA will not show that. Will you get a full service history with the car? How many miles has it done? Would strongly suggest you get a warranty with the vehicle just in case and if they offer you one read the small print!! Let me know what the full VIN is and I will run a quick check.
    Rgds
    Al
  34. #113
    51
    Just to let you know that having completed 50% or work last week, we finished the chain replacement this morning and all is well. Big job and took time, yesterday it was 10am am to 10 pm and most of that was re assembly of the car. We did timing belt as well, changed oil coolant This morning it was the under tray and the wheel arch liner and then all fluids added.
    I reckon I have saved a min 1500, and considering it would have been 400 to change water pump and timming belt, then it inly cost me 100 and 3-4 days work. The module replacement would have been same work plus the removal of top sprocket, and that would have been a *****, and i suggest, only to be tackled by expert garages. I admit the module is more permanent, but the top sprocket was in good nick so a new chain, tensioner and bottom sprocket should let me keep the car for another 50-60 miles before chain has to be replaced again, hopefully, (however some of the Americans on the TDi site have frowned upon my choice!!!). I am low mileage so this is not a problem to me.
    I any one want's any advice then let me know.
  35. #114
    Dec 2008
    32
    weggie - A man after my own heart. Great job as they say in the US. Hope you get many more miles out of the car now.
  36. #115
    Apr 2009
    17
    Rgds
    Al
    hi albarker,could you also check for me aswell?
    8E 1 5A490707,8ED OQC,BLB,HCF DONE 63000MILES
    also who do you contact to see if it got modified?audi customer services?
    many thanks
    A4 AVANT 2.0TDI
  37. #116
    Dec 2008
    32
    OK Guys according to ETKA, the original configuration for the BLB engine oil pump balance shaft is as follows:
    For VINs to number 8E*6*080171 the chain drive is original fit
    For VINs from number 8E*6*080172 upwards the spur gear drive is original fit
    sline29 looks like you may have the chain drive version still fitted. Suggest you check your service & repair history. If you bought the car through Audi and it has been dealer serviced since new, Audi should be able to tell you.
    Please note that the Audi recommended repair (not too sure from since what date) to a chain drive failure is to modify to the spur gear version - . Though, as weggie has done, you can do a repair by replacement of the old chain drive parts as long as the crankshaft sprocket is not damaged as you cannot get that part any more. So that is why the are many variables to consider rather than taking basic data at face value!
    Hope this helps. However, I would just say that you should always check with Audi.
  38. #117
    14
    Rgds
    Al
    I am going to do the checks on Monday with Audi - any suggestions which is the best contact?
    I will also go back and look at the service history that is fully stamped up with the car. It was registered in October 2005 and has done what appears to be genuine 40k miles with just one owner. I have been offered a 12 month warranty but will double check the details.
    The Vin number is [removed as check now done]
    Thanks in advance for the help.
  39. #118
    Dec 2008
    32
    PhilA4 - According to your VIN, looks like you have the later BLB with the spur gear. Suggest you double check with your local Audi dealer to make sure. Unlikely that the service history book will show any repair work. Warranty is worth considering depending on the small print.
  40. #119
    14
    Many thanks I will double check as suggested.
  41. #120
    Apr 2009
    17
    cheers for the reply mate,not the news i wanted to hear though
    so should i phone audi uk?or local dealer to ask if its had repair?
    so i ask if its got chain drive or spur gear drive?is that balance shaft or the oil pump?very confusing
    A4 AVANT 2.0TDI
