Sky InsuranceJMB Retrofits
Page 24 of 29 FirstFirst ... 1417181920212223242526272829 LastLast
Results 921 to 960 of 1147
Like Tree16Likes
Thread: 2.0 TDI oil pump / balance shaft failure?
  1. #921
    Jan 2013
    Moray
    228
    From what I can find, they still run it like the B7 engines, I wonder how they've become more reliable?
  3. #922
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I thought the engines switched to Common Rail so presume they got rid of the hex shaft issue?
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
  4. #923
    Jan 2013
    Moray
    228
    Not sure, i can't find any schematics or exploded diagrams anywhere
  5. #924
    2,178
    No the hex shaft is still there but's beeen redesigned looking at elsawin.
  6. #925
    Jan 2013
    Moray
    228
    So is the answer to fit the oil pump from a CAG engine?
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
  7. #926
    2,178
    Just checked ETKA and common rail engines have different part numbers for both the shaft & oil pump would be surprised if they fitted.
  8. #927
    Jan 2013
    Moray
    228
    Never assume. If anyone has access to parts and could verify, it could solve quite a large problem!
  9. #928
    2,178
    No I would assume, unless you have large pockets to try this stuff out and if it don't work and the engine goes pop due to oil starvation as the wrong pump was fitted, and then have the money to drop in a new one. Even if the pump did line up with the mounting holes, the only way to tell if it's fully working is to fit the pump and put the engine back together and monitor the oil pressure, and then after a few K mile strip it down again and make sure all the gears are still in perfect condition.
    This could be a good idea if you are a company who is going to charge for this replacement service and make money off it then it may be worth it, if you just want your car put back together and working again with minimal cost it's not worth it.
  10. #929
    Jan 2013
    Moray
    228
    I'm going to investigate this one I think.
  11. #930
    May 2009
    south yorkshire
    628
    usually slight noise and if oil pressure warning light comes on turn engine off immediately , you may save the turbo and the engine if your quick . all for the sake of a hex key drive . audi probably got a good deal on allen keys .
    also brother has a cr engine in garage with oil pump failure , but guy has supplied a complete engine .
    once engine is out theyll strip it to find cause and solution
  12. #931
    North East
    607
    Quote Originally Posted by Wrath View Post
    That's why I'm buttering up Bald Man
    Has anyone heard anything from Bald Man about taking up the oil pump/balance shaft issues with Audi or has it all come to nothing ?
  13. #932
    Jan 2013
    Moray
    228
    He will be one of thousands that try and just get the usual response. I've decided to face facts with my car and future proof it this summer whilst the car is going under more work
  14. #933
    Feb 2013
    West Yorkshire
    59
    I am happy to look at this, but I do not have a damaged car, you lot do, come to an agreement between you how you are going to prove an engine design fault and I will fight it, I am not preparing and fighting it pro bono
  15. #934
    North East
    607
    Quote Originally Posted by Bald man View Post
    There is the problem , how does one PROVE the engine design has a fault ?
    I myself have attempted this and have written seven letters to Audi on the matter and all have been met with a response along the lines of our warranty is 3 years or 60,000 miles, whichever comes the earliest. My car had 68,000 miles on the clock and was a little over 6 years old. Despite having a full service history and that I have owned Audis for circa 25 years (I gave Audi all the details) there was no goodwill from Audi other than expediting the backlog of parts so that I received them in six weeks where others had waited three months or more.
    That said the engine does have a latent design defect but now after all this time I for one have all but given up hope of seeing my £2000 repair costs reimbursed.
    Rant over, now how much is a Toyota Avensis ........................................
  16. #935
    Jun 2012
    Hi Folks, forgive me for my ignorance as I am new to all of this.
    My oil pressure light has come on and am assuming that it is the balance shaft problem you all speak of. My car is the Audi A4 2.0l TDI 170bhp B7 model. Engine is the BRD one.
    How easy is it to replace the oil pump on this model? is there a step by step guide anywhere?
    Also has anybody heard of KMB parts direct in Sheffield as I am told they specialise in fitting replacement (longer) hex drive shafts.
    Any advice on the above would be much appreciated.
    Regards
    Lee
  17. #936
    North East
    607
    Quote Originally Posted by leebob View Post
    Regards
    Lee
    If the red light is on and you are still running the engine you have very likely passed its too late to do much about it and you will have very likely wrecked your engine and turbo!
    Read the following for some useful information https://dl.dropbox.com/u/63614250/2....il%20pumps.pdf
    GOOD LUCK
  18. #937
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Equally, my car never manifested the fault before I got it converted.
    Nathan
  19. #938
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Just wondering whether Murran can provide the technical knowledge that you can use to fight this?
    Nathan
  20. #939
    ctd
    Oct 2012
    Plymouth
    105
    the problem is , at least with mine, is there were no symptoms AT ALL, the engine just shat itself, cloud of smoke, loss of power, oil light came on , engine stopped, new engine and turbo required, all happened as quick as you can read this post, doing 30mph after going 1/4 of a mile after leaving a friends house
  21. #940
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    As far as I understand what Baldy Man requires is someone with mechanical experience who can state the problems and has worked on cars with the issue.
    Nathan
  22. #941
    ctd
    Oct 2012
    Plymouth
    105
    he was talking to the guy who changed my engine, not sure how far he got with investigation
  23. #942
    Apr 2013
    London
    Hi,
    First post here. Have recently bought a 2006 56 plate A4 Avant 2.0 TDI 170bhp quattro, engine number starts BRD, 68k miles.
    Sounds like it shouldn't have the chain, but likely to have the hex shaft. Anyone able to say...
    1. Does this car have the hex shaft at risk of the issue ?
    2. Are there any indications of how likely the hex shaft issue is to occur, assuming car is driven to 150k miles plus?
    3. If I wanted to spend to protect against this risk, rough idea of cost ?
    Discovering this risk has taken the shine off my new motor, which otherwise I love. Many thanks for any help and advice.
    Cheers,
    Dave.
  24. #943
    North East
    607
    Quote Originally Posted by davidparcher View Post
    Hi,
    Cheers,
    Dave.
    READ THIS https://dl.dropbox.com/u/63614250/2....il%20pumps.pdf
  25. #944
    Apr 2013
    London
    Quote Originally Posted by Paul B7 View Post
    Thanks Paul. If I read this thread correctly you've had the chain replaced with gear driven, have you done anything to protect against the risk of hex balancer shaft wearing round?.
    I'm trying to decide whether I should do something, and if so which of the options, or live with the risk of the hex shaft rounding. Difficult to decide as no idea what % of shafts will eventually give an issue.
    Cheers,
    Dave
  26. #945
    North East
    607
    Cheers,
    Dave
    "You pays your money and you takes your pick" , there are lots of gear driven engines out there that have not experienced the problems even at high mileages. That said there are a lot of us who HAVE experienced problems.
    i would suggest you set aside two hours and read this thread in its entirety and then make up your own mind as to what's best for you and your budget............good luck and remember at the end of the day the choice is down to you.
  27. #946
    May 2009
    south yorkshire
    628
    The gear driven oil pump which has the hex key to drive the oil pump still has this problem upto sept 2009. I have just had to change the balancer shaft as mine was badly worn on the 2.0 170 cr engine code cah . Car my sept 2008 b8. Purchased the shaft from klm in Sheffield noticed that theyalso do chain driven kits and conversion kits for all effected engine codes. Do a google and phone the guy very knowledgeable and can tell you straight away if your engine is affected by this bad design.
  28. #947
    Macdoon's Avatar
    Essex
    1,569
    Quote Originally Posted by hollow View Post
    Have you got a link mate, I've trawled google and can't find klm in Sheffield
    Mac
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
  29. #948
    North East
    607
    Thumbs up
    Quote Originally Posted by Macdoon View Post
    Mac
    The company is called KMB not KLM, try www.kmbpartsdirect.co.uk
  30. #949
    Macdoon's Avatar
    Essex
    1,569
    Thanks Paul
  31. #950
    North East
    607
    Thumbs up
    When my BLB started rattling these kits were just starting to appear on the market ( by Powermax in ireland) and I opted to have Audi do a geared conversion at just over £2000. If I was in the same position today ( and because my car would be another 2 years older and worth less than when i had the work done) I would try one of these kits.
    Good luck.
  32. #951
    Macdoon's Avatar
    Essex
    1,569
    Good luck.
    Just sent KMB an email, looking forward to what they have to say
  33. #952
    Macdoon's Avatar
    Essex
    1,569
    Ok so had a few back and forth emails from Graham at KMB, so here's my options, they supply a remanufactured balance shaft using the newer 100mm drive key which Audi altered to after Oct 2009. The cheapest way for me would be to buy the part from them at £225 and have my mate fit it, but there is also the option of going to them having them do the work all inclusive £650.
  34. #953
    North East
    607
    Mmmmmmmmmmmm good prices and a lot less than having the Audi OEM conversion done. Good luck with whatever you choose to do.
  35. #954
    Macdoon's Avatar
    Essex
    1,569
    I'm gonna order the parts, good price for peace of mind
    Paul B7 likes this.
  36. #955
    Apr 2013
    Glasgow
    Hi Guys
    My Car was in for an MOT ( 2.0 TDI Sline Avant on a 55 Plate) at Audi Glasgow, the Dealer. I was told that my balance shaft/ oil pump was on its way out and would cost £2600 car is worth £6000 MAX.
    Was not happy as i only has this car for less then 2 years and was bought Approved. with a FSH.
    Any way called Audi UK andasked if they could help.
    Long story Short... 100% of the cost will be paid for by Audi UK
    So its not a complete loss. I would recommend that if you can keep the dealership service. Thats the only reason i got mine paid for.
    The guy told me that this was a result of my loyalty to the group. I have had all service/ repairs MOT with them.
    So Guy if you can buy approved and keep the FSH.it may cost a bit more just now but when/ if you have a major problem. Audi are willing to help.
    The happiest audi Owner
  37. #956
    North East
    607
    Quote Originally Posted by harmeetsaggu View Post
    Hi Guys
    NOW THAT IS A RESULT and you must be one of the few that Audi have recompensed, well done. That said I was in almost exactly the same position as you with an Audi used approved car that had a full service history and was in my ownership for just over two years old and I got nothing, even after writing several letters to Audi Teesside and to the HO in Milton Keynes. AUDI DID NOT HELP ME OR MANY OTHERS ON HERE, SHAME ON YOU AUDI !
  38. #957
    North East
    607
    and ANOTHER THING, I have driven Audis for nearly 25-30 years, most of them have been used approved and Audi gave me BUGGER ALL and yes I did communicate this to Audi HO ...........
  39. #958
    Macdoon's Avatar
    Essex
    1,569
    Quick update, a few more emails back and forth with Graham at KMB, parts ordered and will be posted today
  40. #959
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    Hi Folks,
    Just a quick post here for your info. I have a 2005 A4 TDI with the BLB engine. I''ve 110,000km on it and was concerned about the chain snapping. I was going to get it converted to the PowerMax modified balance shaft and mentioned to an Audi dealer before hand. They came back to me with a price of €1000 to do the full gear conversion, timing belt and oil service. I was pretty happy with that and have had the work done. Great peace of mind! Was it in fact a good deal?
    Cheers,
    2005 A4 S-Line B7 2.0TDI PD140, Pearlescent Garnet Red. Bluetooth, BNS 4.2 Sat Nav, Colour DIS, MFSW. Retro'd: Cruise Control, Ambient light, Dension Gateway CAN Enabled Ipod Interface
    2003 VW Golf IV Highline TDI PD100, Metallic Silver. Bluetooth, Fogs, Sport Seats, Air-Con, Trip Computer, iPod Interface, 18" RS6 Alloys, Colour Coded Bumper Valences, Retro'd Cruise Control.
  41. #960
    North East
    607
    Quote Originally Posted by Bing_IRL View Post
    Hi Folks,
    Cheers,
    GREAT DEAL ! You will also get a 24 month Audi warranty on the work done. I paid circa £2000 for almost the same job ( I had the water pump and full timing belt kit replaced at the same time ) 18 months ago.
