Monster MotorsportEM Tuning
Results 1 to 9 of 9
    droppedaudia4's Avatar
    May 2009
    48
    engine problems black smoke
    my car is a 2005 2.0tdi a4 saloon 140bhp i was wondering if anyone knew a reason why my car has alot of black smoke when reving and is quite hard to start although i think the flywheels the reason why it is hard to start because it needs replacing.
    2005 AUDI A4 2.0 TDI | REMAPPED TO 190BHP | 19 MERC SLR ALLOYS | AP COILOVERS | LED HEADLIGHTS | AMBIENT LIGHTING | CUPRA R FRONT SPLITTER | MORE TO COME ...
    Sep 2009
    Probably turbo seal's. Excesive oil in the exhaust getting burnt produces the black smoke.
    Dont hold me to this, im just going off my past experience with turbo cars lol
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Could also be the re-map? Overfuelling.
    May 2009
    48
    Quote Originally Posted by jwhat View Post
    its not the remap as i took it out last week and it hasnt helped any i thought this at the start too though
    sparks's Avatar
    Glad im back
    Dec 2006
    inverness
    51
    Sounds like could be a fueling problem maybe sticky injectors possibly sticking open slightly more causeing more fuel being injected in which would then give you black smoke and hard to start especially from cold.
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    In the sticks of Derbys & Notts
    168
    Most of the A4 TDi's do it!! I had exactly the same smoking problem (and still do), went to two seperate Audi Stealers with the problem - they all do it was the reply, we cant sort the issue. Apparantly it can be reduced with better quality oil such as Mobil but it doesnt get rid.
    2012 A3 Tdi 170 S Line Black Edition
    Marc1's Avatar
    Feb 2008
    719
    To be honest I would post a video up if you can as one persons excessive smoke could be anothers perfectly normal. If it does show excessive I would suggest it's more over fueling which could be due to a lack of air controlled by the maf sensor. I'd see if there is a member local to you with vag com or take it to a specialist to ensure no codes come up. Equally it could just be bad fuel so you could also try running a bottle of forte diesel additive through the tank to se. If it makes a difference and make sure you are using decent diesel.
    For Sale
    B6 S Line Saloon rear bumper,B6 A4 Upper Grille,B6 1.9TDI catback exhaust,B6/B7 Full Piano black inlays,B6/B7 RNS E/GPS Sharkfin,B6/B7 Side airbags,B7 2.0TDI Intercooler and MAP sensor
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,147
    I wonder if the particle filter in the exhaust has become damaged. My old Leon 1.9 150bhp used to spout shedloads of smoke out the backend but that was a Euro III engine so did not have the particle filter.
    I haven't seen any black smoke from my B7 and I sometimes drive it a bit crazy
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Might you have a boost leak/ air escaping from a broken/old pipe etc.
    I don't think the particle filter was fitted until the 170bhp versions were released.
