Results 1 to 11 of 11
    ntp
    Jul 2009
    37
    How to remove the factory fitted phone cradle?
    Hi all,
    Does anybody know how to remove the factory installed phone cradle stand? I can't find a phone cradle for my HTC Touch Pro so I would like to remove it an make some space for another cradle. is there a guide somewhere that I can use?
    Thanks in advance!
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Is that the one in the dash or the armrest? I've heard of people removing the radio and you can unscrew the cradle from it or something similar but it leaves a little square holes where it was in the dash and the only remedy is a new dash.
    Good 2 B A Gooner's Avatar
    May 2009
    Chichester
    715
    If it's fitted into the side of the radio or climate, then it's easy as....
    Firstly you'll need a set of radio removal keys (check ebay, they're 2.50ish) remove the radio and if needed climate, (if you need to remove the climate - Just give it a tug, and it should pull out) the attachment should just be screwed into the side as it was with my old A3.
    Most parts are easy and cheap to repair in and around the stereo/dash, i had the top part of the din (the plastic that sits above the cup holder/coin draw) and that was only 8!
    If it's fitted into the dash in some way, i can't see you having holes left in the dash...?!
    Or you could just go into your local dealer, they should help you if you speak to the parts department!
    ntp
    Jul 2009
    37
    Quote Originally Posted by Good 2 B A Gooner View Post
    Hi,
    thanks for advice. However, I couldn't understand if I will end up having holes left in the side panel. I will probably remove the RNS-e without a problem but what am I going to do with the wholes. My a4 is all covered by creamy leather and it won't look nice.
    The stand is positioned to the right side of the Sat NAV (RNS-e). Shall I just leave it there then?
    ntp
    Jul 2009
    37
    Quote Originally Posted by jwhat View Post
    Thanks jwhat,
    New dash would be far too expensive.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    New center console for the A4 B7 is 60 ish, an hours work to replace it and a little bit of dremmling if you have an armrest.
    May 2009
    Chichester
    715
    Quote Originally Posted by ntp View Post
    Hi,
    my old cradle had been fixed with screws, but into the inside of the climate cage - meaning you couldn't see any screw holes.
    Can you get a pic on here?
    ntp
    Jul 2009
    37
    That's interesting. I will take a photo tomorrow and post here.
    ntp
    Jul 2009
    37
    I have just taken these pictures and now the question is will I have the holes once I remove the phone stand?
    May 2009
    Chichester
    715
    Think you'd be best to speak with your local dealer mate
    You can just replace that plastice if it leaves holes, but it's a fair bit - On the plus side you could probably put it on ebay after
    ntp
    Jul 2009
    37
    Thanks for the advice.
