AH FabricationsVolks Autos
    Oct 2009
    11
    Aftermarket HID Xenon Kit On 2008 A4 Cab
    seen kit on internet ultimate kit H7r Anti glare bulbs for standard reflector
    does anyone know if it can be fitted without any warnings etc - thanks
    M7R
    Type Approval Engineer,
    Sep 2008
    Chilwell, Notts
    212
    nope. they will run with a relay, chances are it will bring up a bulb failure warning.
    also hids even with the "anti glare" sticker will still give a poorer beam pattern in a hallogen lamp as there will be too much light in the wrong places (lamps are designed to have x amount of light in set areas.... if the light source is 100 times brighter then the light in all areas will be brighter..and some places are only allowed levels on 0.4 lo
    lumans or so.. with a HID they have been show to jump up to 10 or even more.... not good.
    also HIDs will burn the reflector, this will lead to a diteration in the reflector and cause poor reflection control and transmission, again leading to pap lights.
    if you want HIDs get new lights with projector lenses, its the only way to be even vaguely legal...
    projectors will have a Z beam pattern this means then when over taking people on the motorway etc the beam pattern is cut off bellow the other persons wing mirror to help stop the glare as you pass them....hence all OEM hids being Z beam.
    halogens arent anywhere near as bright so dont need the Z beam.
    oh and if you are caught with the HIDS in vosa road side check, good luck... they arent road legal. so your insurance is null and void, and if your hit at hight due to blinding another driver, again good luck.
    the easy option, run proper bulbs like Philips power blue ones, for the white/blue look, or philips extreme for the max light output.
    83 GTi - road legal track weapon - now running 2.0l 16v super charged, = FAST!
    Daily hack: Audi A4 Avant S Line 2.0TDI Motech map to 175bhp, Milltek twin exit system, 1/2 leather, DIS, Fan washer jets, B8 rear aero wiper, FK headlight,
    Oct 2009
    11
    thanks i found a place on the net down south that can supply original audi lights bulbs etc has anybody tried this if so as what cost
    M7R
    Sep 2008
    Chilwell, Notts
    212
    Quote Originally Posted by Benpage View Post
    do you mean oem xenons units? or just oem bulbs? if its just bulbs then er anywhere selling good bulbs will do...
    Oct 2009
    11
    yes oem units complete with bulbs ballasts etc been told the ecu needs
    turning the xenon option on not sure who can do that but then there is the problem of auto leveling and headlamp washer
    M7R
    Sep 2008
    Chilwell, Notts
    212
    ecu needs coding - not too hard with vag com... then you need the auto leveling and headlamp washer to be 100% legal.
    or have these on mine...
    http://www.fk-automotive.de/websale7...15a5b%2fmd5%7d
    not everyone cup of tea but work well and are a bit different.
