AH FabricationsChris Nott
Thread: DV location
    Boulders's Avatar
    Sep 2009
    Cambridge
    19
    DV location
    Hello!
    Think I may have a weak/leaking DV. Am currently running a Superchips map and it feels like it's not holding boost at the top of the rev range any more.
    Had a look around the engine bay and couldn't seem to locate the offending item. Any help or pics would be greatly appreciated.
    Simon.
    Mar 2009
    589
    Jack the car up drop the plastics off and its at the front of the block about half way up !
    Held in with 3 X 5mm allen key bolts I replaced mine with the revised oem "D" valve.
    I pressume you are on about the 2.0t fsi ?
    Boulders's Avatar
    Sep 2009
    Cambridge
    19
    Thanks Marrow,
    trying to see it from the top of the engine bay without my X-ray specs on was never going to work then! Will be getting the revised "D" valve as well, and yes 2.0T FSI.
