DV location
Boulders
Cambridge
Hello!
Think I may have a weak/leaking DV. Am currently running a Superchips map and it feels like it's not holding boost at the top of the rev range any more.
Had a look around the engine bay and couldn't seem to locate the offending item. Any help or pics would be greatly appreciated.
Simon.:uhm:
Jack the car up drop the plastics off and its at the front of the block about half way up !
Held in with 3 X 5mm allen key bolts I replaced mine with the revised oem "D" valve.
I pressume you are on about the 2.0t fsi ?
Thanks Marrow,
trying to see it from the top of the engine bay without my X-ray specs on was never going to work then! Will be getting the revised "D" valve as well, and yes 2.0T FSI.
724
769
33
20K
