    Jul 2009
    14
    Questions on A4 B7 Avant
    I have a few issues and changes id like to make to my Audi
    1. Is there a better guide than this to fix my rattley door handle?
    http://www.audizine.com/forum/showthread.php?p=4097102
    Any advice on doing it? its the drivers side
    2. Is there any info on taking out the silver trin which is about 3 inches and runs from the 2 front doors across the front dash
    3. Is there much info on fitting electric mirrors?
    4. Can i fit a multifunction steering wheel? i dont have controls on mine
    5. How easy is it to change from a single din to a double din, i know its been done penty of times but how easy is it? and what is the final finish like? im after a double din pioneer unit to replace the single din.
    May 2008
    Bedfordshire
    137
    Quote Originally Posted by nwells View Post
    Double din cage is available from ebay, you'll also require a thinner climate panel which will sit level with your front ashtray. You'll also need the fascia for your chosen unit. RNS-e doesn't require any fascia and looks great.
    Cage:
    http://cgi.ebay.co.uk/Original-Audi-a4-8E0-Double-Din-Housing-for-RNS-E-GPS_W0QQitemZ370097577349QQcmdZViewItemQQptZUK_CE_ GPS_Accessories_Software_ET?hash=item562b88dd85&_t rksid=p3286.c0.m14
    Jul 2009
    14
    Would i need to purchase a new climate panel then from ebay also?
