Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    Oct 2003
    South Wales
    2,942
    Cruise control - VAGCOM
    Planning on fitting cruise to my A4, but don't have vagcom at the moment.
    I read somewhere that once the wheel has been off, the steering needs to be reclalibrated using vagcom when put back on.
    Is it safe to fit the parts and then enable with vagcom later?
    Rich.
    Dolphin Grey Audi S3 8P
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Until the steering sensor is recalibrated you won't have working ESP, not sure if the ABS doesn't work either?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Oct 2003
    South Wales
    2,942
    Thanks for the reply, think I'm going to wait until I have vagcom.
    Feb 2009
    Vag-Com
    I have the latest version if you need any help and live in Port talbot
    Oct 2009
    Were can Vag.com Be got from ??
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Quote Originally Posted by akasta View Post
    Check out the VCDS (Vag-com) section on here I think someone in there sells it.
    I got mine from genden
    27,087
    That would be myself & cheaper than gendan but same genuine product.
    Please PM me for further info.
    Thanks.
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Yeah I meant NHN but couldn't remember his user name
    27,087
    No worries mate, thanks for passing it on.
    Oct 2003
    South Wales
    2,942
    Quote Originally Posted by slinedab View Post
    Sorry mate only just seen this post.
    Thanks for your help but I got it all sorted anyway.
    Where abouts in PT do you live mate? I used to live in Westlands, then I moved to Baglan and now live in Skewen.
    Rich.
