Sky InsuranceJMB Retrofits
    May 2009
    Watford
    13
    B7 S4 radiator leak
    i have got a B7 S4 estate and noticed a wet patch on the drive. i looked and found there are 3 radiators on the car, 1 main 1 at the front and 2 smaller ones each side of it. i found the one on the passengers side is leaking and wondered if any one else has had this problem?. its a 2005 '05' and has done 23,000 miles so surely it shouldn't have failed yet should it?
    stevehall's Avatar
    Aug 2008
    Littleborough, Lancashire
    298
    Could this be your AirCon radiator?
    Im not 100% sure but just a guess as i know there is one there for the air con, and then it could just be condensation>
    Steve
    ___________________________
    Audi A4 Avant B7 2.0T FSi Quattro
    Done: | Ambient Light | 18" Audi RS6 Alloys | Westfalia Detachable Tow Bar & ECU | De-Egg | RNS-E | Bluetooth Kit | RS4 Anti Roll Bar | Audi Torch | Full Rear De-Badge |
    To Come: | Audi A6 3.0TDi Le Mans - When I can find the right one!|
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    Radiators are a known issue (I think the auxiliary ones) so I'd get it looked at by the dealer ASAP. You dont want to cook a V8!!!s
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Quote Originally Posted by Cupramax View Post
    That was true on the B6 but the cooling ducts to the auxiliary radiators have been redesigned on the B7 and reduced the problem greatly.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    May 2009
    Watford
    13
    i took the car back to the garage i bought it from and they changed it under warranty luckily. where the air grilles are next to the driving lights, if you look up the passenger side grill you can see the radiator and the new one they've put in looks completely different to the original one the other side so maybe they are a problem and they changed the design as the new one looks a lot stronger
