Volks AutosBadger5
Page 4 of 4 FirstFirst 1234
Results 121 to 143 of 143
Like Tree4Likes
Thread: Just fitted an RS4 Rear Sway Bar - WOW!
  1. #121
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,696
    Do it; you will be delighted.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
  3. #122
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    828
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Added this onto the to do list for this year...
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
  4. #123
    AudiB7Jay's Avatar
    Nov 2012
    374
    Quote Originally Posted by Richardesty View Post
    I think the lot of you should just do what I did.......
    Stop talking about it
    Get your wallet out
    Get your spanners out
    Enjoy the improved cornering ability
    i think I agree, apart from I'm not confident with fixing my audi xD I don't want to break it xD fancy helping me out? Also is there a front arb too?
  5. #124
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    Quote Originally Posted by AudiB7Jay View Post
    Reading the whole thread i think someone mentioned that most of the Front ARB's are the same size, but i'm not going to confrm that lol, as for fitting it, it is a pretty easy job you cant really go wrong... altho.. sometimes it does lol
    Camillia Well don't want to just settle for any average joe now!
    Purdy haha good point, but then again... apparently anything better doesn't exist
    Camillia No it doesn't... Hence why I'm complaining about it... Come on Purdy you can't be this stupid lol
    Purdy lol the hidden point i was saying, is surely it would be smart to stop chasing what doesnt exist.... then maybe... just maybe! it would shut all you girls up who moan about men...
    Camillia Touché
    Classic case of Girls Moaning about Boys...
  6. #125
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,696
    You don't need to change the front anti-roll bar. The front bar is the same for all models. Keep in mind that increasing rear roll stiffness reduces understeer. So it follows that increasing front roll stiffness (by fitting a thicker front bar) would have the opposite effect.
  7. #126
    AudiB7Jay's Avatar
    Nov 2012
    374
    Currently I'm on stock sline running gear n tbh it's very sloppy, I'm hoping to fit these coil overs but while I'm there may aswell do arb's at the same time I guess?
  8. #127
    Dec 2011
    Wales
    106
    Seems like this needs to be done! I will check the drop links this weekend to see whether I need new ones or not. Will post with results when fitted also
  9. #128
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Ramps vs hoist.
    Quote Originally Posted by scoTTy View Post
    If you're fitting them yourselves (or at a garage) remember the wheels should be supporting the weight of the car and not any ramps, axles stands etc.
    If you don't do this, once you've fitted the bar the rubbers, etc will twist as the wiegh goes back on. Basically you'll be clamping it in a position that's not it's normal resting place.
    This is why the Audi instructions make it clear not to do it with the wheels hanging.
    Being old-fashioned, I think of ramps as being the wedge shaped metal frameworks that cause teh wheels to continue to support the weight of the vehicle, but approx 10" above the ground.
    And the original hydraulic ramps are moving "wheel tracks" that can be raise many feet into the air.
    Can you not use either of these to install the RARB, or will I *have* to get the car on the ground to bounce the suspension to settle the mounts before completing the clamp tightening?
    A hoist, however, may allow the wheel to be hanging free, as is needed for many servicing operations (but not this one)
    Obviously, if you let the wheels hang down, then the shape of the ARB is extended slightly (end to end), and so cannot be fitted without excessive force.
    I'm surprised about the comment about the bush sizes; too much sticking and there will be residual lean, but too slack, and the roll-resistance will be decreased. So fitting the "A" bushes to the 22mm ARB might be slightly sticky, and will be worst when initially fitted, and will only wear into a "better" more nominal state. Of course, fitting the right "D" bushes to the 22mm ARB will have the right level of "give" to reduce vibration, etc.
    A4 B7 Cabrio 2007 2.0 TDi Black "Sport"
  10. #129
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    I note that saloons and Avant have this mod; is there enough stiffness in the chassis of the cabriolet to benefit from this mod?
    Or will it result in rattle of the whole bodywork?
    Anyone done it on a Cabrio?
    Edit: Just come across Fitting a cabriolet with uprated ARBs - guidance needed where this is mentioned; no actual info about the actual benefit of fitting to a cabrio.
  11. #130
    Dec 2006
    Herne Bay, Kent
    74
    Love the difference it made to my cab.
    jimbooboo likes this.
    2006 3.0 TDI Sline Cab, Auto, Phantom Black, Bose, Bluetooth, F & R PDC,
    Retrofit 2010 RNS-E, Aux In, Cruise, LED Numberplate Lights, RS4 RAB, Mtecc Drilled and Grooved Discs, Vredstein Ultrac Sessanta's
    To Do, auto lights, windscreen washers and dimming mirror.
  12. #131
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Quote Originally Posted by rhinoman View Post
    Thanks for the reply.
    I will put this on the list; yet more card pain!
  13. #132
    Big Al's Avatar
    A4 2.0T FSI engine knackered!
    May 2011
    West Midlands
    304
    I recommend the RS4 RARB too, see my build thread for details, part numbers, costs & photos.
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
  14. #133
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    435
    I fitted one to my cab and it made such a difference. For the cost it's a good modification to do.
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
  15. #134
    Jun 2010
    63
    Got mine in today to get this done. Can't wait to get it back.
  16. #135
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Ordered the bits on Saturday from Audi for just under 140 GBP (including bolts for exhaust and drop-links)
    Awaiting delivery, and then good enough weather to get out and install.
  17. #136
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Quote Originally Posted by Tolak View Post
    Bits have arrived, but then so has the weather.
    Next stage is to get some free space in the garage, and then some free time to enjoy that space!
    maikysupra likes this.
  18. #137
    dpaz's Avatar
    Oct 2011
    Lincolnshire
    332
    Fitted mine last Saturday. Roundabouts are now a completely different experience.
    Best description I can come up with is that fitting an RS4 ARB "sure's up the back end".
  19. #138
    Oct 2013
    30
    In two minds wether to get this done...Luke from east Kent Audi said the cabs only show an S4 as the biggest bar but on the avant of course they have the rs4 bar...does anyone think the rs4 version would be a problem for the cab?
  20. #139
    Dec 2006
    Herne Bay, Kent
    74
    Got an RS4 one on mine.
  21. #140
    Oct 2013
    30
    Whats the verdict? Or did I need ask the question lool
  22. #141
    Dec 2006
    Herne Bay, Kent
    74
    I said earlier in the thread, love it.
  23. #142
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Quote Originally Posted by dpaz View Post
    One of the benefits is meant to be that it reduces the understeer, so it "sures up the front end", as well.
    Moving the action of keeping the car flat to the rear wheels means the front can be left with lower task loading, and can keep the two tyres at even contact force, so both wheels contribute to the steering. When the rear is softer, the front has to help keep the car flat, and so the inner wheel has lower contact force, and helps less with the steering.
    Ultimate is when an inside rear wheel lifts, and the car is in tripod mode; at this point, the rear axle has done (almost) all it can to keep things stable, and the front has to start compromising its down-forces.
  24. #143
    Jun 2014
    39
    Just been reading start to finish on this , sounds like the way to go.
    As there has been no updates for over a year i wanted to check what the situation is re part numbers.
    I was going to order parts this week but would like to check the definative parts listing /reqiurements as of june 2014 to ensure i get the correct part numbers etc.
    any updates would be great guys .
    rob
