JMB RetrofitsBadger5
Results 1 to 9 of 9
Thread: more bass!
    M7R
    Type Approval Engineer,
    Sep 2008
    Chilwell, Notts
    212
    more bass!
    is there anyway of running a separate sub in the A4 Avants with symphany head unit? as I assume it doesnt have co-ax outs on the back? as I want a little more bass than the normal set up can give (dont get me wrong the OE set up is veerryyyyyy goood!! but I do like my big bass)
    cheers
    Karl.
    83 GTi - road legal track weapon - now running 2.0l 16v super charged, = FAST!
    Daily hack: Audi A4 Avant S Line 2.0TDI Motech map to 175bhp, Milltek twin exit system, 1/2 leather, DIS, Fan washer jets, B8 rear aero wiper, FK headlight,
    mike beech's Avatar
    Jun 2009
    Lancashire
    42
    i added an Infinity Basslink enclosed sub and amp unit to my TT coupe with bose a good few years ago, that had the symphony head unit.
    I think, but its only think.... there should be a set of rca outputs on the rear of the headunit (cant remember - it was around 2004). Would deffo recommend the unit, its got a 10inch sub inside, is nice and compact and has plenty of whoomp to it. Think it cost about 130 all in as well and I fitted it in a couple of hours.
    2006 B7 A4 2.0T Quattro S Line Avant - RNS-E Sat Nav - Bose - DIS - PP 250bhp remap - SOLD
    M7R
    Sep 2008
    Chilwell, Notts
    212
    aahhhh!!!! Ill pop the head unit out tomorrow then and see! cheers dude.
    g60jet's Avatar
    May 2008
    UK
    147
    use a line level converter off the sub in the boot you already have *behind the right hand boot panel"
    |Present: 2005 B7 Audi A4 Avant 2.0T FSI Quattro S-Line|DIS|Phatbox|Aircon'd Glove Box|Ambiant Light Pack|
    |Gf's Motor: 2003 8L Audi A3 18.T Sport | Standard |
    |Previously: SEAT LEON FR TDI|German Spec Corrado G60 JET LHD|Mk2 Golf Cab|Mk2 Fiesta 1.4s|
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,525
    Quote Originally Posted by mike beech View Post
    The Symphony II doesn't have RCAs (nor does the Symphony II+), but it does have line level outputs. WThe rear line level signals are always used so adding a sub in parallel would mess up the impedance and levels, so you should add a line doubler to generate a separate line level signal for the sub amp - and control the sub amp from the same amp enable signal as the OE amp.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    mike beech's Avatar
    Jun 2009
    Lancashire
    42
    Karl,
    Now dave has mentioned it I think I may have soldered in some RCA's off the high level outputs. That Infinity Basslink has high level inputs too, I know I've mention the thing twice now but for the money it was spot on and it wasn't too obtrusive in the small boot of my TT.......wish I could have been bothered to take the thing out when i sold the car.......
    mike beech's Avatar
    Jun 2009
    Lancashire
    42
    Just stumbled across the link I used when fitting the RCA's to my TT, it should be a similar process on the rear of your stereo.....ahhhh old age memory loss, its all coming back to me now.....and I'm only 32.....be jesus.......
    http://www.wak-tt.com/mods/subwoofer/subwoofer.htm
    M7R
    Sep 2008
    Chilwell, Notts
    212
    cheers dude, give me something to think about and play with if the Audi stays.
    Sep 2008
    London
    50
    Is they a how to for the A3 with RNS-E with bose......I would like to add a 8" active sub to the current set up
