JMB RetrofitsAH Fabrications
Thread: Alarm LED's
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Very good, how did you achieve that?
    I take it the led strip is an add on also.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    I added the led strips ages ago - the work via a switched ignition supply so they're 'always on'.
    As for the 'alarm' - I used a circuit that is in effect turned on, when the ignition supply turns off - and therefore flashes the 2 led's whenever the ignition is off - unless I've switched the override switch!
