s4 tyre wear could this be geometry
lazygee2
NULL
I am having problems with tyre wear on the inside I have lowered the car by 40mm could the camber or geometry be wrong where and how is the best way to resove this issue as the car is eating tyres, any help would be much appreciated,greg:s4addict:
Did you get the alignment set properly after the drop? If not then it needs to be done.
Not sure if it'll be Audi figures you should use. What kit did you use to drop it? Are there revised alignment settings with it?
12
2K
506
13
2K
17
6K
