Monster MotorsportEM Tuning
    Jun 2007
    69
    Clear Headlight Indicator Conversion
    Hi, I have been loaned a 57 plate a4 cab at the moment, mine is a 06, is it possible to retro fit the clear headlight indicator lenses into my 06 like those on the later cars or are they a sealed unit?? Thanks, Andrew
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    If you check out post number 63 on the following thread, it appears it is possible - however you will have to take your headlight apart........
    http://www.audizine.com/forum/showth...=233279&page=3
    Might be worth dropping the guy a line.
    I'm lucky in that my A4 came with crystal optics, something I insisted on when looking around, but I've since turned them into daytime running lights (see avatar)
    Rich
    M7R
    Type Approval Engineer,
    Sep 2008
    Chilwell, Notts
    212
    you need to change the full unit for a later one.
    Im going to be trying the black out mod soon, so ill post up how I get on
    83 GTi - road legal track weapon - now running 2.0l 16v super charged, = FAST!
    Daily hack: Audi A4 Avant S Line 2.0TDI Motech map to 175bhp, Milltek twin exit system, 1/2 leather, DIS, Fan washer jets, B8 rear aero wiper, FK headlight,
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    There's is another way .... some guys on Audiworld have posted how to convert the orange headlights into white ones. You remove them from the car, stick them in the oven at home and heat them up until the glue holding the front and back together softens, then prise them apart and pull off the bit of orange plastic. Then you stick them back together again and put them back on your car.
    I'm not joking....
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
