Sky InsuranceEM Tuning
    Sline
    Nov 2006
    6
    Lowering a quattro ?
    I have not lowered a quattro before, is there anything I need to be aware of?
    I have a B7 A4 2.0TFSI Sline quattro and the time has come for it sit lower to the ground-
    I have ordered a set of KW V1's
    I have heard that the rear camber needs adjusting...is this true ?
    cheers
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    When ever you lower any car you'll need to adjust the camber at all 4 corners as it'll be out with lowering it.
    Damian @ DPM
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Sline
    Nov 2006
    6
    Quote Originally Posted by DPM View Post
    Damian @ DPM
    I know you have to get the tracking re done and camber adjusted but what I wanted to know was do I need to buy any additional parts to allow the camber to be setup correctly like adjustment links?
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Nope - you're good to go once your coilovers turn up.
    Mine is dropped on FK Automotive Konigsports - check out my thread for pics:
    pics: 2.0TQ S-Line SE, coilovers, clear corners
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    Jul 2008
    Manchester
    Quote Originally Posted by ultramodz View Post
    Hi ultramodz
    How much of an improvement are the coilovers over the standard s-line suspension in terms of handling ?
    I am thinking of changing mine to a set of coilovers as I feel the s-line standard suspension has a bit too much roll in it around corners, although its fairly decent over bumps.
    Im wondering if the money would be better spent in uprated anti roll bars instead ?
    Nov 2003
    London (N8)
    515
    Quote Originally Posted by kquattro View Post
    Hi ultramodz
    I've probably got my coilovers a touch too low to be optimised for handling, but it's definitely an improvement, in terms of body roll reduction & turn-in.
    You may want to consider upgrading to the RS4 rear sway bar, all the details for part numbers, etc are here: http://www.audizine.com/forum/showthread.php?t=105668
    Audizine is a great forum to join - a lot of the guys in the States have already made the majority of performance mods you may be considering & it's great to get their feedback... Not that this one isn't great though!
    Anyway - if you want your car to be firmer & also look purposeful & lowered, coilovers are the way to go.
