AH FabricationsSky Insurance
Results 1 to 13 of 13
    dan888's Avatar
    Jun 2007
    UK
    12
    Retro Fit Acoustic Parking Sensors
    Has anyone retro fitted these parking sensors to an A4?
    http://www.abacuscaralarms.co.uk/ala...se-sensors.htm
    If so I'd be interested in what they are like? (bearing in mind they are only 99 and can be fitted without drilling the rear bumper)
    And how you would wire them into the reversing light circuit?
    Dan
    2006 - Audi A4 - 2.0 TDi 140 - S Line - Multitronic
    Sep 2008
    7
    did you decide to go with these, or did you choose something else
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    I've just fitted one of these to my A4, really quite impressed - and like it says - there's no drilling involved, so the car looks standard.
    http://www.parkingdynamics.co.uk/Veh...1#installation
    However - the hidden side of our rear bumpers are a bit awkward to feed the sensor through......
    Rich
    Sep 2008
    7
    i went for original audi ones in the end they are well good pick up everything
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by Richardesty View Post
    Rich
    Hello mate
    Any pics of them fitted?
    (I'm sure you have)
    loves quattro
    Oct 2008
    Louth
    753
    as it happens, I'm halfway through relocating the 'wire' - cos I took the easy route first time, mounted it low down and ended up picking up the road when I backed out of my drive way........
    So - the green line shows were the sensor is now mounted, having passed it behind all the support moulding, the red line shows where I originally mounted it.
    Although I went for the one with the LED display
    If you look on the left you can see the 'end' of the sensor (C) sticking out from the tape - this just connects to a wire, which in turn goes to the control unit.
    For the new position, I taped the sensor to the end of a hacksaw blade, passed it through behind the moundings, then taped it into place using black Duck tape.
    And here's what it looks like when it's finished :
    Mar 2008
    Dorset
    13,856
    Not exactly an easy fit then!
    They are certainly discrete! So discrete I can't even see them Where are the sensors in the bottom pic?
    loves quattro
    Oct 2008
    Louth
    753
    The very bottom photo shows the car once put back together. The whole idea is that you can't see the 'sensor' cos it's the metallic strip which mounted inside the rear bumper, as shown on the first photo
    Installation is really quite easy - once you work out where all the fixings for the rear bumper are
    Mar 2008
    Dorset
    13,856
    Ah I see, sorry my mistake. I thought you had fitted the ones from the bottom link that go on the number plate surround. Your's looks a very discrete clever system, do they work ok?
    loves quattro
    Oct 2008
    Louth
    753
    Technically no 'they' don't.........however, 'it' works a treat
    (There's only the one sensor)
    Oct 2003
    South Wales
    2,942
    Hi Rich,
    Atfer having them fitted for a while now, would you recommend them?
    Any issues with them?
    Rich.
    Dolphin Grey Audi S3 8P
    loves quattro
    Oct 2008
    Louth
    753
    Yes I would recommend the kit I used..........
    The only downside is false readings when the rear bumper is either wet, or indeed covered in snow!!!!
    Other than that - it's great
    Oct 2003
    South Wales
    2,942
    Cheers. Think I'l order myself a kit.
    Rich.
