Volks AutosEM Tuning
    catdog's Avatar
    Feb 2006
    Hong Kong
    10
    Red face Any harm with excess engine oil?
    As titled. In my case it's minimal, just a quarter inch on the dipstick, which someone told me is equivalent to less than a half litre.
    But if the amount is a bit more than that, will the excess get burnt off as white smoke out of the exhaust? And will it cause other damages? Many thanks
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    It could damage your catalytic converter
    Built in Germany, Perfected in England
    enda1's Avatar
    Jan 2006
    Ireland
    439
    It could also blow the oil seals in you engine. The pistons going up and down pressurise the crank case and if the excess oil prevents this pressure from escaping it can blow the seals
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Or it could blow it out at the weakest point, too much oil is just as bad as too little. Have you checked the oil level on level ground ?
    catdog's Avatar
    Feb 2006
    Hong Kong
    10
    It's actually my mate's car, I was just asking for him. Thanks a lot guys.
    I have already told him to fix the problem.
