Badger5JMB Retrofits
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    retro fitting options...
    Is it possible to retro fit any of the following and has anyone attempted any of them ?
    Auto dim rear view mirror
    Auto lights
    rain sensing wipers
    MFSW with paddles
    Steve
    Jan 2007
    Hampshire
    1,155
    You could tie in the first three together but wont be cheap as you'll need a new screen as thats where the rain sensor is, obv the mirror needs replacing as well! you'll also need a new headlight control switch for the auto-lights but its certainly do-able.
    MFSW much easier but again wont be cheap, new wheel and possibly new steering wheel ECU and slip ring may be required, And of course access to VAG-COM, All very do-able though.
    I just completed retro-fitting auto-dimming exterior door mirrors, a bugger of a job but well worth the effort now its all done I feel.
    A6 3.0 TDI.
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    hmmmm i'll look at the windscreen, my present golf has the rain sensors and i know rhwy asked when I needed the replacement screen. The actual sensor is built into the mirror. I have the dimming mirrors on the GOlf as well and once you have had them its difficult not wanting them again, I always thought they were a gimic but after a hired astra I missed them.
    Jan 2007
    Hampshire
    1,155
    The light sensor is in the rear-view mirror housing, the rain sensor sits above it on the under side of the screen, I guess you might be able to fit the sensor to your original screen but I doubt it would look OEM.
    Drove 200 miles last night in the dark and the dimming exterior mirrors were great, worth the aggro of fitting them for sure.
    A6 3.0 TDI.
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    How expensive is it to retro fit the dimming mirrors ?
    Jan 2007
    Hampshire
    1,155
    The mirror glasses come up on ebay from time to time. Not cheap from Audi though, no surprise there I guess - they are around 160+ vat (each!)
    A6 3.0 TDI.
