AH FabricationsJMB Retrofits
    si_reading's Avatar
    May 2007
    Cheshire, UK
    168
    New A4 Cab: Offset/PCD
    Hi,
    Doesn't anyone know the offset/PCD etc for the new A4 Cab?
    I've got some new A3 S-line 18" wheels and need to know if they will fit on an a new A4 Cab if possible.
    Thanks,
    Si
    Si
    2009-Current | Porsche Boxster 2.7
    2007-2009 | Audi A3 2.0 TDI 170 S-Line
    2005-2007 | Audi A3 1.6FSI Sport
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    They will fit as both cars are 5x112 PCD but the offset is a bit low for a Cab so they'll look more inset than the standard wheels and you may get rubbing problems on the inner wheelarches on full lock. A3 wheels are ET54 and standard A4 wheels are ET45. I have a set of ET42 RS4 replicas that I had on my Sportback and they stuck out a little too much on that but are spot on on the Cab.
    si_reading's Avatar
    May 2007
    Cheshire, UK
    168
    Brilliant thanks for your help :D
    Si
    si_reading's Avatar
    May 2007
    Cheshire, UK
    168
    Could spacers be put on if needs be to give a few extra mm's to push the wheels out a bit?
    Si
    Si
