Results 1 to 9 of 9
    Smudge973's Avatar
    Sep 2004
    Harrogate
    128
    Know much about Mobil 1 ESP Oil ? ?
    Having checked the oil which has been used by Audi for my 1st AVS service, They used the following....
    Mobil 1 ESP 5W-30 - No mention of longlife ?
    There is a litre in the boot, which upon investigation prompted this thread.
    Having looked at the Mobil 1 site, there is also no mention of longlife.
    Be interested to know if anyone else has come across this ?
    ta.
    Phanton Black A4 2.0 TDI Multi, B&O, AMI, NAV, 19" wheels
    DavidR's Avatar
    Scotland
    1,295
    I know nothing about it.
    However, VW has approved oils the standard of which is coded. The codes are listed in the owners manual for the car and should be written on the bottle of oil...
    If you crossmatch you should be able to determine whether it is a long life compatible oil.
    Smudge973's Avatar
    Sep 2004
    Harrogate
    128
    Thanks, also noticed that there have been a number of comments about this oil.. I should have searched first.
    DavidR's Avatar
    Scotland
    1,295
    It is longlife compatible. Checked with the Exxon / Mobil webpage.
    Smudge973's Avatar
    Sep 2004
    Harrogate
    128
    Quote Originally Posted by DavidR
    I have checked, as mentioned.
    Since posting, my research concluded that this oil is approved and correct..
    Thanks.
    Teutonic_Tamer's Avatar
    GreasedMonkey HoofHearted
    Aug 2004
    Swampyland, UK
    122
    Erm . . . be careful, very careful with Mobil oils.
    Mobil are know to lie about the VW (and other manufacturer) approvals on their oils.
    The Mobil 1 ESP 5w30 is a VW approved LongLife oil, but the standard Mobil 1 definately is NOT VW approved, even though Mobil state it on the bottle.
    I would personally avoid any Mobil oils, and merely recommend any of the European OEM specced oils, such as Castrol, Shell, Fuchs, Elf or Motul.
    Sean - Independent Motor Vehicle Technician (retd)
    2007 Audi B7 (8EC) RS4 quattro saloon 4.2 FSI V8 32v (BNS) (with ceramic brakes ) - V-max = 9.8mpg @ 172 mph - WOW
    2006/7 VW A5 (1K) Golf Mk5 GTI 5dr 2.0T FSI (BWA) DSG, fully loaded, colour coded,
    1998/9 Honda CBR600FX - the blueberry trifle
    2003 Audi B6 (8E) S4 quattro saloon 4.2 V8 40v (BBK) 6sp man, fully loaded (gone, but not forgotten)
    Aug 2004
    Swampyland, UK
    122
    Quote Originally Posted by phil1978
    Correct me if I'm wrong, but I believe Mobil Exxon suply lubes to Castrol
    Nope, you are very wrong. Mobil have never supplied Castrol. Mobil is part of the Exxon Mobil Corp, which includes the Mobil and Esso brands. Until a few years back, Castrol was a wholly independent brand, but is now part of the BP "empire" which includes BP, Amoco, Burmah, Castrol, Duckhams & Aral.
    . . . . I used to work for Mobil Oil and without a doubt Mobil 1 is one of the best oils available.
    That is an extremely generic and "wooly" statement.
    Mobil 1 is shyte for compliance with later OEM requirements.
    Yes, in its' day, Mobil 1 was a very good lube, about 15 to 20 years ago, before the days of OEM specs, when the likes of the original API, and the later ACEA generic specs were the norm. Unfortunately, todays OEM specs are considerably more rigorous than the pathetic API specs, and the improved ACEA standards, and Mobil oils just havn't kept pace with modern lubrication demands.
    Just dont use normal Mobil 1 for AVS as its (best) life is approx 13-14 months.
    Didn't I say that up there ^^^ ??
    So it is perfect for a 10,000 miler or annual service.
    No it is not, as it doesn't comply with any of the modern VW standards (even though it lies on the bottle!).
    Which is why they made the Mobil 1 ESP, same as the Castrol SLX Longlife II ( now called edge).
    Again, you are wrong. The Mobil 1 ESP is a 5w30, and has been tested to meet the 504.00/507.00 approvals. These are LongLife 3 approvals, not LongLife 2. The two differing standards, in certain engines, are NOT interchangeable.
    phil1978's Avatar
    Dec 2004
    Home of the white stilleto
    183
    Thanks for clearing that up Sean, got my sleepy head still on, worked nights last night. Sorry for any confusion.
    07 A4 Cab 2.0T FSI S-Line
    06 Suzuki GSXR750 K6
    Gone But Not Forgotten:
    04 A4 Tdi Quattro Sport
    03 Golf GTI T
    If in doubt go flat out
    Aug 2004
    Swampyland, UK
    122
    OK, no worries.
    Just don't try posting when you are p!$$ed !!!
