Volks AutosBadger5
    Jan 2006
    Durham, England
    Brake Warning Light After Brake Pad Change
    Can anyone help Ive just changed the front brake pads on my Audi A4 Cabriolet 1.8T 2003 but ever since the pads have been fitted the computer tells me the pads need changing do you have to reset the ecu or computer or is there anything else you have to do. Ive checked the connections from the pads and everything seems OK.
    scoTTy's Avatar
    Essex, UK
    1,958
    Re: Brake Warning Light After Brake Pad Change
    It's simply a circuit. If the connections good then the light goes out.
    Try popping the wire out the holder, shorting the two sides and seeing if the light goes out.(Remember to try on both sides). It could be an issue with the cabling rather than the pads?
