JMB RetrofitsSky Insurance
Results 1 to 13 of 13
    Jun 2014
    10
    Avant water leak
    Morning all. Well I've only had my 05 a4 avant 2.0t for 3 weeks and last couple of nights we've had a few down pours and thunder storms. Well I've opened to rear passenger door and the top of the seat is wet and seams like it's leaking water from the top of the door.
    Has anybody else suffered with this and how do I go about fixing this problem.
    This sort of thing I would expect from a vauxhall not an audi.
    North East
    607
    This sort of thing I would expect from a vauxhall not an audi.[/QUOTE]
    Unfortunately Audi are these days no better than any other car and a lot worse than most.
    They trade on the name forged in the 80's and early 90's and there reliability and quality today are a myth based on some rather good marketing.
    Rant over, good luck with your water issue.
    Jun 2013
    247
    Have a good look around the seals for any damage or poorly fitted rubbers
    Jun 2014
    10
    We'll I have had a good look around the rubbers and there all in great condition. Luckily enough my dad has a 2008 a4 avant with only 28k on the clock so it was ideal to check out his door rubbers. And what I noticed was that the rubber around the door on my car have gone flat where on my dads car they still had there shape.
    Jun 2013
    247
    probably your problem, how does the door fit, does it fit tight & line up with the swage lines, is it twisted at all, ie does it stick out at all at the top ?
    Jun 2014
    10
    Nope, I've been all the way around it checked and double checked everything, Even done the same with my dads to see if I could find any difference between them and how they fit. That's how I found the rubber was squashed.
    Well knowing audi prices it won't be cheap lol.
    Jun 2013
    247
    Not sure on this without looking at mine but you may be able to remove the seal & rotate it a bit so it's then in a different position.
    Jun 2014
    10
    To be honest with you mate I don't think you can as I think there a made to fit seal. Made to the correct shape. Not like a mk2 golf lol.
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    Here's a trick. Use a little sellotape to stick kitchen roll around the door seal. Shut the door and gently poor water over the door shut. Open the door to see which area is letting in the water. You should be able to adjust the fixed metal catch on the rear arch (which the door latches onto). Loosen the screws and adjust the bracket inwards. Then the catch holds the latch and door closer to the bodyshell. I've adjusted all my doors to reduce the wind noise as the rubbers squash down over time. A new door seal maybe cheaper at TPS or Euro Car Parts. Good luck fixing it!
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    27,099
    Usually new seals needed tbh as they do go flat over time, but try the striker plate as mentioned.
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    476
    Possibly worth a wee look around the seal on the roof bar fittings? I had my bars off last weekend and the interior trim has a hard plastic back so might be leaking in and running down the back of the trim.
    Jun 2014
    38
    you could allways hire a small portable smoke machine to find any leaks around seals etc.
    had an old alfa with similar problem, a guy i know used one and it showed up the leaking door seal straight away otherwise very hard to find a leak as water runs down even the smallest gap and crevis.
    rob
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    Quote Originally Posted by A4Rob View Post
    rob
    If you're going to get a smoke machine, I think you need a decent strobe light too. Then put some hard trance music on the stereo and you're sorted!
  1. b6 avant water leak,,,carpets soaked arghhhh
    By jamesey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th October 2013, 19:31
  2. Water leak in rear of a4 avant
    By nickf in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th June 2011, 10:14
  3. Water Leak in the Cabin
    By bampy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2004, 18:00
  4. Water Leak on Drivers Side
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2004, 07:20
  5. Help, S4 water leak!
    By Futureman in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2003, 20:11
