Results 1 to 9 of 9
    Anito's Avatar
    Dec 2003
    Chester
    429
    Reversing lights delay
    Has anyone else noticed that when you engage reverse there is a .5 -1 second delay before the reversing lights coming on?
    Is there a particular reason for this?
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Re: Reversing lights delay
    This might be set in a control unit. I think that it is actually for automatic cars. An auto goes from "park" through "reverse" to get to "drive", and the delay is to stop the reverse lights from coming on as it passes through "reverse". I have an auto B6, and it does not have the delay. I always see the reverse lights come on when I go to "drive" at night. It can't be doing the bulbs any good.
    d5aul's Avatar
    Jan 2006
    Kent UK
    26
    I noticed this with mine also, mine is a 2.0 TDi Manual.
    Anito's Avatar
    Dec 2003
    Chester
    429
    I could understand the 'auto' argument but mine is manual. Perhaps its uses the same control unit
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,663
    How worried are you by this?
    Anito's Avatar
    Dec 2003
    Chester
    429
    [ QUOTE ]
    [/ QUOTE ]
    Not in the least. I'm just cureous & It's obviouosly by design as other B7's I've driven do it
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,663
    I guess it's just a case of German thoroughness.
    Nov 2003
    114
    mine is the same, the parking sensor do a wee confirmation beep when reverse is engaged
    Jul 2005
    UK
    13
    B7 A4....same thing. Also have you noticed that the headlights have a mini delay when you turn on as well. Plus the indicators sometimes don't seem to be "connected" to the stalk. I guess everything is controlled electronically by a central "relay" rather than control by the individual stalks...
