EM TuningAH Fabrications
Results 1 to 8 of 8
    May 2014
    170 tdi flat spot/turbo not working properly
    Hello everyone,
    I brought a 170tdi (BRD i think) a few weeks ago and found it has got a problem with the turbo. When pulling away from junctions the car will accelerate to around 2500rpm and then plod along for a few seconds before the turbo kicks and then carry on accelerating. When it does this it puts out a lot of smoke.
    There are no fault codes and the garage I brought it from had a look but couldn't find the fault.
    Any help would be great thank you.
    ruairi83's Avatar
    Dec 2007
    731
    Maybe the turbo actuator is sticking or the veins
    Have you had car scanned with vcds
    May 2014
    Yeah and it didnt find anything which was annoying! The actuator rod seems to move nicely so I don't think the veins are sticking. It is strange that once it is boosting it is fine
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,658
    The garage you bought it from needs to look harder. Under current sale of goods regulations, for the first six months after the purchase, the burden of proof is reversed, so your garage has to prove the car is of satisfactory quality and fit for purpose. You do no have to prove it is not.
    Go back to the garage, tell it you are rejecting the car as being not of satisfactory quality or fit for purpose, and force it to either repair the car or give you your money back. That should concentrate their minds a little bit.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    May 2014
    Im writing a nicely worded letter at the moment and will add that in. I said i would like my money back and they said they wouldnt refund me as there are no fault codes and the garage they sent it to couldnt find any leaks etc. Im going to ask an vag specialist to write a letter to confirm it isnt working as it should to back me up.
    It would be a lot easier to get my money back if i knew what the problem was. Shame really because its a great car apart from engine problems lol
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,658
    But that's the point of the reversal of proof in the legislation. You don't have to prove it's faulty. The garage has to prove it isn't.
    May 2014
    They are saying they have proved its good by getting a separate garage to scan it and to try and fix it! Ill send them a letter tomorrow and I'll put a few quotes from the sale of goods act in. I dont think its going to be easy getting my money back. Thank you for the help
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,658
    Good luck, and let us know what happens.
  1. Turbo not working properly + stalling? Audi A3 1.8T 2001
    By sparx in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2009, 23:27
  2. A4 19. TDI Flat spot
    By chunky0411 in forum Diesel forum
    Last Post: 22nd March 2006, 13:04
  3. Latest threads not working properly
    By imported_Yaseen in forum Site Support & Announcements
    Last Post: 20th February 2005, 22:50
  4. TDi Flat spot
    By imported_YOGi in forum Diesel forum
    Last Post: 9th November 2004, 18:03
  5. pc sound not working properly? Help
    By Dumpvalve1 in forum General Chat
    Last Post: 27th September 2004, 22:26
Tags for this Thread
