Results 1 to 11 of 11
    Jan 2014
    82
    A4 avant sun shades
    Hi all,
    I've not long had my first little girl (8 days old today!) and with this hot weather and sunshine I am trying to keep it out of her eyes.
    I bought 2 el cheapo ones which just sucker to the window, but the rear boot windows are a weird shape and I can't seem to block it, even with the load cover shade up.
    I have seen on ebay they do a fitted tailored set for £100, seems a lot but if they are well made, a good fit and mean I can use remote windows still when hot then I could be persuaded to spend some more.
    Just wondering what everyone else uses really and see what options I have.
    Cheers, Mark.
    27,126
    Congrats on the new addition, I remember when my Issy came along, which was in Italy, so I just got the windows tinted mate which helps reflect the heat, deal with UV & protect her eyes, not needed any shades since
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,690
    Tried using made to fit shades, but then switched to tints.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Jan 2014
    82
    Ah really, I'm not too keen on the tinted look, so it would be the slightest tint possible, would 95% tints block enough light? What are you all running tint wise? I'll have to see a few pics as the front clear and rear dark doesn't look right to me.
    Thanks for the input. Also, is there much cost difference?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,690
    Here's my saloon, with 80% tint. You don't need to go higher than that; they block out plenty. They cost £175 (probably more like £200 for an Avant).
    Jan 2014
    82
    Don't they work the other way round? As in a 95% tint allows 95% of light through? I'd prefer a less obvious tint to that if possible.
    How good a job did they do of the tint? I've read in the past its something you want done well and done poorly looks terrible. Would you agree with that? Thanks again.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,690
    I've never been able to remember which way round the percentages work. You're absolutely right that it's a job that has to be done well. Luckily, I gave a guy near me (North Kent) who is top notch.
    EDIT: I've just checked back to my thread when I had the tints put in. It was a 20% tint, which blocks out 80% of the light. According to what I was told at the time, the OEM factory tint is 30%, so blocks out 70% of the light. On that basis, I can't see how such a thing as a 95% tint can exist.
    Jan 2014
    82
    Okay, thanks for looking it up. Basically I'd want the clearest film possible to top up the slight factory tint without being too noticeable. But taking the edge off of the sun, asking a bit too much here I think!
    I might look into getting some tester bits to see what u can get away with.
    Cheers, Mark.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,690
    Quote Originally Posted by novril View Post
    Cheers, Mark.
    If you can't find the right solution with tints (and I suspect you might not), then have another look at shades. You can get a tailored fit set from a company called Vanstyle, or even from a Seat dealer, because remember the Seat Exeo estate is the same car as your A4 Avant.
    seandom's Avatar
    Dec 2012
    Hampshire
    133
    I think it depends what colour your car is also. Mine is brilliant black and looks great with the limo tints. Which I believe are 5%IMG_96022775869868.jpg
    Mar 2014
    York
    37
    This is mine, when I first got it I wasn't too keen on the tints, but they've proven their worth with the sun we're getting at the moment!
  1. Rear window sun shade
    By Ben H in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2014, 10:13
  2. Sun Shades. Fitted with pics.
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2013, 23:40
  3. Sun Shades
    Last Post: 4th October 2012, 08:29
  4. Front sun shade doesn't go to the edge of the window?
    By crapo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2011, 12:01
  5. Rear sun shade on parcel shelf
    By funkyr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2010, 22:51
