EM TuningVolks Autos
    Jul 2013
    29
    Drivers Headlight cut out HELP!!!!
    Hi guys im in need of some help!
    driving along yesterday with dipped beams on, all of a sudden the drivers dipped beam not working light popped up, i tried replacing the bulb (which was fine) no joy, tested the bulb and it was ok, i'v tried un-plugging the unit and checking for corrosion, all looked ok, i've tried reseting the ecu (unplugged battery for 10mins) as i've heard the ecu will cut the power as there is no fuse for headlights, i'm at a bit of a loss, the next option is remove the headlight, re-wire the dipped beams and see if that works, otherwise i dont know what to do? Has anyone experienced this issue? Or have any idea what it could be?
    thanks for any help its much appreciated!
    Jan 2012
    1,837
    And the headlights are? Xenon, halogen? OEM, aftermarket?
    Start with a fault code scan.
    Jul 2013
    29
    Sorry halogen headlights
  1. HELP!!!!! CAR CUTTING OUT HELP!!!!!!!!!!
    By dannyvalley in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th February 2012, 20:20
  2. Emissions light is on - and it cut out, help!!!
    By wolfy1988 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2011, 13:54
  3. 3.2Q cutting out - HELP!!
    By Relaxitscool in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st March 2011, 20:44
  4. Engine cutting out...help
    By Crashlanding in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2009, 08:05
  5. Help 18.T keep Cutting out! Help urgently
    By locker in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2008, 07:34
