Monster MotorsportEM Tuning
    Jun 2014
    egr blanking kit problems
    I have recently fitted a egr blanking kit to my 2.0tdi and have had some problems,
    With the two plates on the car doesn't run properly and has a big loss in performance,
    With just the one plate on the preformace is ok and car seems to run fine but has now gained a noise like it has a dumpvalve which seems to happen when the turbo kicks in.
    Any Ideas?
    Dec 2011
    Somerset
    499
    Egr will need mapping out or buy a blank with a hole.
    Jun 2014
    Quote Originally Posted by Gazwould View Post
    I know this would get rid of the engine management light but would this help with the performance? Any ideas if it would get rid of the dump valve sound?
    May 2014
    15
    Hello mate i would suggest getting it mapped out as the lad before said as i fitted one with a hole and the car ran absolutly terrible and i had to take it back off
    Jul 2014
    7
    As above, my dad did this on his fabia vrs and r tech said it should be mapped immediately after the blanking kit is fitted. Cheeky excise to get it mapped I think. If it's already mapped then they can simply map map the egr out.
  1. Allard 'Powerpipe' EGR delete kit Vs EGR blanking plates?
    By BudgieV8 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2011, 19:52
  2. EGR Delete kit problem - 19TDI ASZ
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2011, 20:21
  3. EGR Blanking cap
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 14:45
  4. Votex Body Kit Problems
    By Boyakasha in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd January 2006, 16:39
  5. A4 and RamAir induction kit problem
    By shinto in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd September 2003, 22:59
